Brake issue.
So anyway. I deleted ABS and Im running an aftermarket Prop valve. Tonight I went to bleed my brakes, I started with the rear and everything was fine. Air was coming out, started to get a harder pedal, complete stream of fluid after a couple of cycles. Then i went to the front and it seemed to be working, started to get a steady stream of fluid. But the issue began when I realized the pedal wasn't going down when the fluid was going out. Then I realized that there was no pressure on either front brakes.
Any ideas?
The stream of fluid is consistant with the rears and seams fine, the only issue is the pedal doesn't fall to the floor like it should when the bleeder is open. And there is no pressure on the front brakes.
I thank you in advance to any help or ideas.
Any ideas?
Chilloutdamn
Nov 4, 2008 03:24 AM
Driven
May 26, 2003 03:29 PM
