boost guestion
Ive been working on my friends civic this weekend. He just recently had a turbo kit installed and the shop that installed it they put a block so you cant raise the boost. How do you raise the boost?
The second question I have is about the blow off valve. To make the blow off valve work louder..do I adjust it softer or harder?
Modified by silver-16v at 6:17 PM 3/30/2008
what EMS is he using? does he have a boost controller? one way of upping the boost is by getting a larger spring for your WG and letting it run with it.
as for your bov, at 5PSI, i think your just not pushing enough air through it to make the sound youve probably heard on other higher boost applications.
anywho, if you dont know what im talking about by getting a larger wg spring, take it back to the shop.
yeah I know what your talking about. I think he is just going to go and get it tuned at a different shop that installed the kit. The shop that installed it did it half ***. Thanks for all the help guys
