For all of you piecing together your own turbo kit! (Roll Call)
Old Jul 9, 2002 | 08:39 PM
CalvitoSol's Avatar
Default For all of you piecing together your own turbo kit! (Roll Call)
This topic was brought up on an earlier post and thought it would be a good idea if everyone that's doing the custom/junkyard setup should post their partlist, post pics of finished install and maybe share your experience w/ us. well here's my list so far and about half way done.
Parts: Price
used t3/t40e Turbo..........................................$40 0.00
RevHard Manifold.......................................... ..$310.00
tial wastegate w/ dump tube.............................$250.00
custom oil cooler for turbo................................$55.00
various gaskets........................................... ....$100.00
ngk bkr7e............................................. ..........$15.00
dsm injectors w/ cleaning by cruisin perf...........$150.00
downpipe.......................................... ..............$100.00
misc hardware (clamps, hoses, etc)...................$200.00
Autometer boost guage (b/c it has psi readings).$60.00
Greddy egt guage............................................$ 150.00
gauge pod............................................... ........$30.00
halmeter af30.............................................. ....$200.00
XS boost controller........................................ ...$100.00
custom exhaust w/ gutted cat............................$300.00
intercooler....................................... ................$400.00
intercooler piping............................................ ..$100.00
bov (hks or blitz)............................................ ..$200.00
msd ignition set (ext coil, wires, dist. Cap)..........$150.00
hondata........................................... ................$650.00
grand total:............................................ ..........$3920.00
yea, its coming out to be more than i planned/imagined but i gotta start working around this to lower the price, any suggestions/ideas? thanx and keep em coming!
Old Jul 9, 2002 | 08:42 PM
CalvitoSol's Avatar
Default Re: For all of you piecing together your own turbo kit! (theory48)
ttt
Old Jul 9, 2002 | 08:47 PM
TurBoXBirD16's Avatar
[QUOTE]
Parts: Price
dsm injectors ...........$50.00 NO CLEANING
cheaper way maybe?
Old Jul 9, 2002 | 08:59 PM
CalvitoSol's Avatar
Default Re: For all of you piecing together your own turbo kit! (xbird)
wouldn't i still need something to monitor the a/f ratio?
Old Jul 9, 2002 | 09:04 PM
M.A.R.C.'s Avatar
Koo this is mine...
Turbo System:
>South Florida Performance OR Pann Auto T-3 Turbo Manifold
- SFP = $400, Pann = $300. If i go Pann I have to make a custom downpipe, if i go sfp, i can buy their dp for $150
>Custom OR South Florida Performance Downpipe (depends on manifold)
>Custom Charge Pipes (JC Whitney)
Garrett T-3 Turbocharger (.60A/R, 60-trim comp, .48A/R turbine)
Starion Intercooler
Apex'i Twin Chamber Blow Off Valve
Tial 35mm .45 Bar Wastegate
Fuel System & Tuning:
DSM 450cc Injectors
88-91 Injector Resistor Box
255lph Walbro High Pressure Intank Fuel Pump (FPH003)
Calterm GM Injector harness clips
Electronics & Gauges:
Apex'i V-AFC
Greddy Turbo Timer
Autometer Sport-Comp A/F Ratio Gauge
Autometer Sport-Comp Boost Gauge
NGK BCPR7ES-11 Spark Plugs
Miscellaneous:
>Turbo Performance Oil Line Kit
>Silicone couplers
>Air Filter
>Other miscellaneous crap
only items with a > next to it are left to buy
Old Jul 9, 2002 | 09:09 PM
CalvitoSol's Avatar
Default Re: For all of you piecing together your own turbo kit! (CivicRyda2k)
wow, pretty similar to what i had planned but getting side tracked. so your running the hack? how's that working for you? how boost you running? any reliability problems?
Old Jul 9, 2002 | 09:37 PM
Firedrake's Avatar
Well, here are my comments to your list I'm assuming this is on some kind of OBD1 B-series motor in a civic or 'teg?
- Well, you can buy used, but I'd rather get a brand new one for $250 more and not take any risks.....
- SFP makes some KILLER manifolds.....I especially like their GSR manifold design, hit up my site to see what kind of power we're making on SFP manifolds...but they're about $140 more than the revhard
- You should be able to find a tial 35mm for like $200, and they include a dumptube flange.....just weld a small segment of pipe on there and clamp some flextube to it for a dumptube and save yourself $50....
- $55 is probably on the high end.....an oil cooler really isn't necessary though....I'd spend the money on a better manifold or a new turbo personally.....
- A little high, but good to have some room to mess with
- Yep
- Send them to RC, same price ($50 for injectors, $100 for cleaning)
- You'll need some 2.5 inch pipe and a 2.5 inch mandrel doughnut to cut.....you may need one more 90 degree bend, but all those won't cost you more than like $40 and some welding
- A little high $$$
- More like $50 (yeah, I'm bein picky )
- Good call
- Why? You have an EGT, spend $100 for some dyno time somewhere with a wideband, tune there, and spend the $100 you save on something else
- Used stuff I imagine? Pricing for this kind of thing is tough to judge, hopefully you'll find a good deal on someone selling a used IC off a kit with piping....if you make your piping out of aluminum mandrel, it'll probably be closer to $200
- Get a turboXS type H and save yourself $70
- If you get it used, but it's not really necessary if you need the money somewhere else
- Hondata RULES!!
Overall a pretty complete setup......you have an aftermarket clutch to hold the power already? I'm kinda sleepy so hopefully I didn't say anything stupid.....you'll love 'da boost, just do it right and tune it right...
Brian
Old Jul 10, 2002 | 07:58 PM
M.A.R.C.'s Avatar
turbo's not on the car yet
Old Jul 10, 2002 | 08:06 PM
CalvitoSol's Avatar
Default Re: For all of you piecing together your own turbo kit! (Firedrake)
[QUOTE]- Why? You have an EGT, spend $100 for some dyno time somewhere with a wideband, tune there, and spend the $100 you save on something else
how does that work? do they take out the original one an just plug it into there or do i need an extra bung somewhere?
[Modified by theory48, 5:06 AM 7/11/2002]
[Modified by theory48, 5:07 AM 7/11/2002]
Old Jul 10, 2002 | 09:06 PM
jdblack1's Avatar
Mine
5psi, 93 octane, 4 degrees of ignition retard
1st gen dsm turbo and intercooler $25
Junkyard, I bought more than one setup so I got this cheap
I modded the wastegate alittle
1st gen dsm bypss valve and pipe $50
dsmtrader.com
CRX HF exhaust manifold $50
internet
custom adapter $$$free
I made it
Down pipe $15
advance and local muffler shop
Oil line block fitting adapters to 1/8 npt $27
mcmaster-carr
Including 1 1/8 npt cross
1 1/8 bspt male to 1/8 npt female adapter
1 1/8 npt male to 1/8 bspt female adapter
and a few 1/8npt close nipples
Oil line and hose ends to the cross $free
got loads of stainless hose at work
Coolant lines $free
Friend's dad owns a ford dealership
throttlebody adapter $4
Ace TrueValue
VDO boost gauge $35
Summitracing
Autometer A/F gauge $55
Summitracing
Sunpro oil psi gauge $15
Advance Auto
Different links and bends of 2.5" radiator hose $35
Advance auto
2 fish tank checks and T's $9
Local pet store
Hose clamps were what I got from junkyards during removals
APC air filter $15
Autozone
Del Sol radiator to allow for dsm smic to be a fmic $90
Internet
I think that's it.
[Modified by jdblack1, 6:07 AM 7/11/2002]
Old Jul 10, 2002 | 09:11 PM
jdblack1's Avatar
Default Re: For all of you piecing together your own turbo kit! (jdblack1)
pictures http://personal.lig.bellsouth.net/li...ics/025_25.jpg
http://personal.lig.bellsouth.net/li...ics/013_13.jpg http://personal.lig.bellsouth.net/li...ics/014_14.jpg http://personal.lig.bellsouth.net/li...ics/019_19.jpg http://personal.lig.bellsouth.net/li...ics/023_23.jpg
Old Jul 10, 2002 | 09:23 PM
CalvitoSol's Avatar
nice, what kinda fmic is that? btw, i noticed the intake side of your turbo is facing the other way. any reasons why? I'm still trying to figure how to put my kit together so i'm asking alot of questions. thanx
Old Jul 10, 2002 | 09:30 PM
jdblack1's Avatar
It's a 90 Plymouth Laser side mount intercooler. I just cut stock brackets and welded on my mounts.
as far as the compressor on the drivers side the turbine is in good line with stock exhaust.
Old Jul 11, 2002 | 09:08 AM
Firedrake's Avatar
- how does that work? do they take out the original one an just plug it into there or do i need an extra bung somewhere?
Dyno's with wideband O2's stick them in the tailpipe in your muffler to read the A/F mix. If you install your EGT properly (in the turbo manifold, on cyl 3 if possible) and learn how to read it, that's all the info you'll need about how lean/rich you're running AFTER the wideband tuning at the dyno......
Brian
Old Jul 11, 2002 | 09:20 AM
CalvitoSol's Avatar
ic, i should start researching that. but those cheap autometer's a/f gauges w/ all the lights are so pretty! lol self.
Old Jul 11, 2002 | 09:40 AM
M.A.R.C.'s Avatar
yah... egt is better. a/f isn't as accurate and pretty much only reads at WOT. Although once i tested my a/f with the afc on my car (only intake). Totally stock the car would read say the last few greens, with the intake it would go a couple bars up towards stoich (but still green), then i put the afc to +2% then it went back down to all the way green. hehe. can u tell i had too much time on my hands?
Old Jul 11, 2002 | 09:44 AM
M.A.R.C.'s Avatar
hey where u gettingthe maxrev manifold for $310?
Old Jul 11, 2002 | 04:13 PM
CalvitoSol's Avatar
that's a decent price right? i got it on ebay and the guy was local so i saved about 15 bux on shipping
Old Jul 11, 2002 | 04:36 PM
technine's Avatar
Turbos not on the car YET:
T3=$50
oil & coolant hoses and clamps=$20
BOV=$12
Adjustable cartech FMU=$60
HF manifold=Free from old motor swap
B&M FP Guage=$34
Autometer Boost=$50
Autometer A/F=$60
Oil pan fitting=free (custom)
charge pipes=$20 (custom)
I am planning on getting a fuel pump and IC a soon as I can, but I might run without one for the moment without going max boost and driving conservativly until I get an IC. But it's not on yet so I don't worry. What helped me out the most is having the spare motor to mount all my parts on and fit it right so I know I am not missing anything. The cartech FMU is pretty nice because it has an adjustable static FPR and a rising rate one too so I am using it on my NA setup right now and it works real nice. I am going to try it without the fuel pump and look at the fuel pressure and the a/f guage (and read plugs) to see if I really need one (I now some peeps that run without a high pressure one and they run well w/ FMU).
Hopefully later I might get an AFC and go for the AFC hack with some 450cc injcetors.
steven_highet
Sep 21, 2015 09:01 AM
93DituneEX
Feb 6, 2006 05:20 AM
StreetEG
Sep 1, 2005 06:06 AM
DigitalFusion
Jul 4, 2004 12:34 AM
CalvitoSol
Jul 9, 2002 02:45 PM
