**HELP with AVC-R settings**
Old Mar 30, 2008 | 10:44 AM
odishaw's Avatar
Default **HELP with AVC-R settings**
hey guys so we were tunning my car yesterday with the avc-r (turning up the boost) now only thing is, when we turned up the boost and then adjusted the duty accordingly we could not get the avc-r to hold a steady boost at 18lbs
is there some sort of trick to working with the avc-r that were missing?? any help with this would be great thanks alot
Old Mar 30, 2008 | 03:13 PM
Tony the Tiger's Avatar
Default Re: **HELP with AVC-R settings** (odishaw)
Could be indication that your wastegate spring is too soft (running more than 1.5x the base spring pressure), or your turbo is choking and running out of flow.
You can max out the duty % on the RPM vs Duty scale... Whatever RPM your boost is dropping, raise the duty there. If it is no good, then it is something mechanical related.
Old Mar 31, 2008 | 08:36 AM
odishaw's Avatar
Default Re: **HELP with AVC-R settings** (Tony the Tiger)
hm cuz im running a gt2871r with internal wastegate that was min. 14lbs
Old Mar 31, 2008 | 01:45 PM
Blown90hatcH's Avatar
Spiking, falling off, Up down Up down????
Old Mar 31, 2008 | 08:55 PM
odishaw's Avatar
Default Re: **HELP with AVC-R settings** (Blown90hatcH)
up and down its like a wavy line
Old Mar 31, 2008 | 10:27 PM
Internal wastegates, especially on the GT2871R is nothing but trouble at anything over 14 PSI.
At this point, you may have to run a really stiff internal wastegate spring to get it to hold 18 PSI; With a really stiff spring though, it would result in quite a bit of spiking.
You either have to live with a wavy boost curve, or switch to external unfortunately.
Old Apr 1, 2008 | 04:37 AM
Try and increase the boost pressure and decrease the solenoid duty.
Urinemachine
May 12, 2010 01:53 PM
allsho
Feb 6, 2007 12:42 AM
vg7z
Sep 20, 2006 08:27 PM
2LiterTurboSeR
Aug 25, 2005 11:04 PM
SOHC_MShue
Mar 14, 2005 03:00 PM
