HELP oil retern and oil feed ??
Old Mar 29, 2008 | 05:35 PM
goldex420's Avatar
Default HELP oil retern and oil feed ??
i know its a newb question but iam a noob when it comes to turbos so could some one pls explain the procces of this and how to hook it up
thanks in advance
Old Mar 29, 2008 | 05:36 PM
turbodano's Avatar
Default Re: HELP oil retern and oil feed ?? (goldex420)
Oh god!!!
I suggest you seek out a shop to help you.
Old Mar 29, 2008 | 10:43 PM
almostboostedgsr's Avatar
Default Re: HELP oil retern and oil feed ?? (turbodano)
Dont give him that kind of ****. Seriously two years ago I asked the exact same question and today I know **** load about turbo honda's.
Okay the turbo feed line your going to want stainless because it gets hot. Your going to want -10an stainless braid.The line runs from the turbo to the back of the block. Your going to want to get a two port adapter one port for the oil pressure sensor and one port for the oil feed line. Then screw the adapter in the spot where the oil pressure sensor was. Then screw your oil feed line on one of the adapter ports and the oil pressure sensor on the other port. Then run the line from the port where you put your oil feed line to the port on the turbo.
The oil return.your going to want it stainless aswell. You first have to take your oil pan off and mig or tig weld a -10an fitting on the side of the oil pan making sure you dont make the hole to low or to high on the pan. Then your going to use a -10an 45degree angle fitting and screw it on the pan. Your return line is only roughly 12inch's in length. Now connect the oil return line that is running from the pan to the oil drain port on the turbo.
Now your done. I hope that helps.
Old Mar 30, 2008 | 08:39 AM
Topdawgg's Avatar
Default Re: HELP oil retern and oil feed ?? (almostboostedgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by almostboostedgsr &raquo;</TD></TR><TR><TD CLASS="quote">Dont give him that kind of ****. Seriously two years ago I asked the exact same question and today I know **** load about turbo honda's.
Okay the turbo feed line your going to want stainless because it gets hot. Your going to want -10an stainless braid.. </TD></TR></TABLE>
this is funny... you tell the guy not to "give him that kind of ****" yet you feed him with some incorrect info...
I guess you DONT know a **** load about turbo hondas
-10an RETURN line..
-3an or -4an feed line, with a proper restrictor..
Old Mar 30, 2008 | 05:40 PM
goldex420's Avatar
thanks very helpful and to the one who says i seek a shop i work in a body shop but we rarely deal with engine work
Old Mar 30, 2008 | 05:43 PM
stealthmode62's Avatar
Default Re: HELP oil retern and oil feed ?? (Topdawgg)
This will show you how it's done.
http://stealthmodeperformance....shtml
Old Mar 30, 2008 | 05:47 PM
goldex420's Avatar
Mn hell yea i like to see the culture growin up here . thanks that was very helpful. do u know ne meets in MN? iam near hastings and twin cites
Old Mar 30, 2008 | 05:50 PM
goldex420's Avatar
very helpful iam still new to turbos but i think iam getting it down pretty good, u know any Mn meets?
Old Mar 31, 2008 | 11:32 AM
Default Re: (goldex420)
I wasnt talking about the line. I was talking about the fittings. They are both -10an.
Old Mar 31, 2008 | 11:43 AM
mighty137's Avatar
hpe this helps....its a -8 an where a -8 fitting was welded to the oil pan.....
Old Mar 31, 2008 | 11:48 AM
EF9ZC's Avatar
if your new to turboing a honda this is also a good article to read http://www.beesandgoats.com/bo....html pretty much tells you everything you would need to know
Old Mar 31, 2008 | 05:49 PM
goldex420's Avatar
Default Re: (EF9ZC)
could ushow pics on the block of the oil feed in detail pls
Old Mar 31, 2008 | 06:41 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goldex420 &raquo;</TD></TR><TR><TD CLASS="quote">do u know ne meets in MN? iam near hastings and twin cites</TD></TR></TABLE>
I only run with the most elite backyard mechanics. We don't attend public meets, car shows, or car club events at Starbucks.
Old Apr 6, 2008 | 05:07 PM
goldex420's Avatar
okkkkk. iam new to the area and work at a body shop and all we work on is classic cars so i was just trying to see whats up with the honda community in wi/mn. iam from TX but moved up here
Old Apr 6, 2008 | 05:23 PM
jmm96gsr's Avatar
Default Re: (almostboostedgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Topdawgg &raquo;</TD></TR><TR><TD CLASS="quote">
-10an RETURN line..
-3an or -4an feed line, with a proper restrictor..</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by almostboostedgsr &raquo;</TD></TR><TR><TD CLASS="quote">I wasnt talking about the line. I was talking about the fittings. They are both -10an. </TD></TR></TABLE>
And it still doesn't make sense.
To the OP - just go with a Stealthmode kit.
Dre90
Apr 20, 2010 04:11 PM
Gtimportfanatic
Oct 31, 2007 09:06 PM
94preluder3084
Jun 8, 2007 09:46 AM
MikeMAN
Jul 2, 2002 09:25 PM
slingshotsi
Sep 9, 2001 06:11 PM
