D16 TROUBLEEE!!!
Okay guy i swap a d16z6 into a 96 civic coupe change the intake manifold, dizzy, and alternater to obd2 so the obd2 wiring harness works with it, but everything done and it start up right away but when i drive it it acelerate really slow even when i push the gas pedal all the way down and on any gear and it . it takes forever to rev high even with the gas push all the way down what could be the problem..?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superfast666 »</TD></TR><TR><TD CLASS="quote">u probly have the map sensor and the tps sensor switched</TD></TR></TABLE>
If that were so, the OP would have definatly stated that. With no TPS reading, the motor will jerk very violently and suddnely when the gas is applied. You really cant miss that.
Crasian
25
Jul 28, 2005 02:10 PM
