Just Bought a 2000 Civic Si, Seems like its low on power.
Old Mar 29, 2008 | 07:43 AM
HondaS2000's Avatar
Default Just Bought a 2000 Civic Si, Seems like its low on power.
I just bought a 2000 civic si, its got a header and intake. car seems like its really slow.. not sure whats wrong with it. I hear vtec working but doesnt pull.. my buddies got a stock si and he put about 5 lengths on me. I replace the plugs and wires with ngk. car idles and runs perfect but when i floor just dont go anywhere. any ideas??? oh yeah and its not throwing any codes...
Old Mar 29, 2008 | 08:24 AM
Evilparadize's Avatar
Default Re: Just Bought a 2000 Civic Si, Seems like its low on power. (HondaS2000)
Check for any vacuum leaks, replace the gas filter and wash the intake filter.
Old Mar 29, 2008 | 08:43 AM
VN712's Avatar
Maybe do a full tune up, instead of just the wires?
Cap/rotors/fuel filter/air filter/basic bolts on, etc.
Regardless, You have to rev the hell out of the b16 to get power.
Old Mar 30, 2008 | 07:43 AM
t0kyoStatus's Avatar
Default Re: (VN712)
the car has a brand new injen SRI. I fixed the leak it had from someone installing the intake wrong. i heard a lot on here about the dizzy cap.
what are the rotors? i guess i could search
the header makes vtec scream but you cant feel it pull any harder. maybe im just used to my poor man type R i had before could be.
sometimes it seems too kinda bog through the lower rpms.
Im going to put a test pipe, i think the cat could be clogged. Change the fuel filter.
My friends Si has three codes for his CEL. And still puts bad lengths on me. This cant be. And he's the one needs the driver mod.
_thanks for any help!
Old Mar 30, 2008 | 07:46 AM
cimo463's Avatar
Default Re: (t0kyoStatus)
If your Cat was clogged it would not idle perfect like you stated.
Old Mar 30, 2008 | 08:36 AM
category5 SI's Avatar
Default Re: (cimo463)
what kinda header is it? I've had several different ones on mine and some really made performance suffer. Car ran fine but didn't pull hard with certain ones.
Old Mar 30, 2008 | 09:59 AM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cimo463 &raquo;</TD></TR><TR><TD CLASS="quote">If your Cat was clogged it would not idle perfect like you stated.</TD></TR></TABLE>
That's not true.
While a clogged cat (in what you're speaking of, VERY clogged cat) CAN throw ur idle - it usually won't.
Old Mar 30, 2008 | 11:52 AM
the car came with a brand new ebay meagan header 4-1. I dont think it would cause such a power loss. Im getting stomped by LS civics and si's. Its almost as if im running only on 3 cylinders. But that would throw a code im sure. I guess ill get a full inspection of the car with a compression test n' all.
Old Mar 30, 2008 | 12:04 PM
wearyfurball's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0kyoStatus &raquo;</TD></TR><TR><TD CLASS="quote">the car came with a brand new ebay meagan header4-1.</TD></TR></TABLE>
Might be your problem.... Most 4-1 headers have clearance problems... You might have dented the header and its not allowing enough flow.... Check it out..
Old Mar 30, 2008 | 12:10 PM
BryanM.'s Avatar
Resident Gearhead
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0kyoStatus &raquo;</TD></TR><TR><TD CLASS="quote">sometimes it seems too kinda bog through the lower rpms.</TD></TR></TABLE>
I had this problem when I had an exhaust leak at the header/cat flange. The more throttle position, the more it seemed to bog.
Old Mar 30, 2008 | 12:12 PM
BEE1's Avatar
Default Re: (mcvtec)
try resetting the ecu
Old Mar 30, 2008 | 12:14 PM
Redbone's Avatar
If u could describe what the car is actually doing, we could probably be of more help. Is it making any strange noises when u are accelerating? Does it bog when u stomp on it? Does the car sputter at lower rpm's? Does the car have a lopey idle or is it steady?
Cap and rotor are simple as hell to replace and they are both on the dizzy. I'd say try the fuel filter and possibly ur FPR could be done for or even ur fuel pump. If the car isn't gettin enough fuel then u r going to experience power loss. Clogged injectors? There are so many different possibilities.
Old Apr 2, 2008 | 08:49 PM
Default Re: (Redbone)
What is an FPR? The car idles perfect. When accelerating half throttle id say around 4,000 RPMS it sputters a little bit for a few seconds. Kinda of like its hesitating on and off. I would try and put some fuel injector cleaner in it but the only gas I pump has techron with i thought cleans the injectors somewhat.
Any other suggestions?
Old Apr 2, 2008 | 09:12 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
FPR = fuel pressure regulator.
Check your cam and spark timing. Those two cause LOTS of "weird" issues.
kelemvor
Jan 30, 2019 07:05 PM
Purple_Hatch
Aug 23, 2016 09:13 PM
bonylad
34
Apr 9, 2008 10:35 AM
mortificationrock
12
Sep 19, 2007 06:27 AM
killaj12
Apr 20, 2005 11:06 AM
