Engine died, no spark
Old Mar 28, 2008 | 08:41 PM
dskater411's Avatar
Default Engine died, no spark
So I was driving home last night and my engine just stalled while in gear.
I pulled over, and tried cranking the engine.
Battery and alternator seemed fine, it cranked forever.
So next I listened for the fuel pump under the back seat and heard it working when i put the key to ignition position.
Finally I pulled all the spark plug wires and watched them while I cranked. No spark.
My question is what are all the possibilities for me to check here if its spark?
Dont think its the wires or plugs since they all went out.
I was thinking maybe distribtor igniter but wouldnt that give me a CEL?
I have no CEL by the way.
Thanks.
Old Mar 28, 2008 | 08:55 PM
Former User's Avatar
Default Re: Engine died, no spark (dskater411)
Yeah, prime suspects would be the coil and igniter/ICM in the distributor. You should also check for blown fuses and have a look at the timing belt -- it may have snapped.
Old Mar 28, 2008 | 08:56 PM
EkFG's Avatar
stick a screw driver in the plug boots then almost ground the screw driver but leave a 1/4 gap between the screw driver and the ground spot check for spark then. if no spark it might be your coil. you can check those with an ohm reader and get the spec's from a chiltons or haynes.
Old Mar 28, 2008 | 09:36 PM
dskater411's Avatar
thanks. yeah i checked fuses, timing belt, and spark from cap to wires, nada. looks like ill open the distributor up tomorrow and check the coil and igniter
whiterichard70
Feb 9, 2013 03:05 AM
leon1990
Jul 7, 2012 01:00 PM
Crossbreeder
Aug 16, 2010 05:52 AM
vxnine
Oct 12, 2004 04:27 PM
EGB18
11
Oct 1, 2004 04:24 PM
