Ground Question???
Old Mar 28, 2008 | 08:18 PM
MrMug3n's Avatar
Default Ground Question???
I plan on cleaning up my discusting engine bay this weekend and wanted to know if its safe to relocate the ground on the valve cover to the rear? ( A to B )
Old Mar 28, 2008 | 08:26 PM
EkFG's Avatar
Default Re: Ground Question??? (MrMug3n)
that would not be a good ground source, you should use the same bolt its on but in stead bolt the cable on the back. (B) has no contact with the cylinder head but bolt (A) does I hope you understand me.
Old Mar 28, 2008 | 08:30 PM
EkFG's Avatar
Default Re: Ground Question??? (EkFG)
this might clear it up for you.
Old Mar 28, 2008 | 08:32 PM
MrMug3n's Avatar
yes i know, the spot that was circled B was poorly discribed i want to ground it there but with the valvecover end closer inward not the end that overhangs the timing belt. i guess my biggest concern would be crossing multiple grounds but i dont think thats an issue in this case
Old Mar 28, 2008 | 08:36 PM
SICKEST@EM1's Avatar
I heard you van make your own ground kit
Old Mar 28, 2008 | 08:37 PM
EkFG's Avatar
I was thinking about grounding the valve cover to the block that would make a good source of ground and would look clean. Then again you might have to ground the block so you dont run into issues. an extra ground can hurt.
Old Mar 28, 2008 | 08:38 PM
MrMug3n's Avatar
Default Re: Ground Question??? (SICKEST@EM1)
Yes you can but like everything else, people that just do things F thigs up! Like the last owner of this car better to play it safe and do a little research
Old Mar 28, 2008 | 08:39 PM
MrMug3n's Avatar
true
Old Mar 28, 2008 | 08:44 PM
EkFG's Avatar
on my gsr im going to ground the vc on the back side to the block. then ground the back of the block to the car. That should work, and look clean. Im going to wait untill it gets warm here to do a wire tuck and run a ground of the harness to the vc. know thats cooler then Flava Flave
GsDAteg
Oct 10, 2007 01:55 PM
mortificationrock
Jun 15, 2007 03:25 AM
sinfulj32
Suspension & Brakes
14
Apr 14, 2006 11:58 PM
onyx00
Jul 6, 2005 01:05 PM
phayzeone
Audio / Security / Video
18
Apr 30, 2005 05:40 PM
