How to ground 2 amplifiers?
Old Apr 25, 2005 | 02:43 PM
phayzeone's Avatar
Default How to ground 2 amplifiers?
I am going to be installing 2 amplifiers. Can I just hook seperate spades for both ground wires and bolt them to the same bolt or do I have to use a distribution block?
Old Apr 25, 2005 | 03:08 PM
audioroach's Avatar
Default Re: How to ground 2 amplifiers? (phayzeone)
a distro block would reduce the change of ground loops in
your system. Also you do not want to use an exiting bolt. Make your
own ground point.
Old Apr 25, 2005 | 03:44 PM
phayzeone's Avatar
Default Re: How to ground 2 amplifiers? (audioroach)
Would using 2 different ground points work?
Old Apr 25, 2005 | 06:10 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phayzeone &raquo;</TD></TR><TR><TD CLASS="quote">Would using 2 different ground points work?</TD></TR></TABLE> Ground both amps at same point, as close to amps as possible, don't use disto. block, [just resistence at the connections] use an existing bolt, [why drill a hole in your car] 94
Modified by fcm at 7:05 AM 4/26/2005
Old Apr 25, 2005 | 11:21 PM
n1mr0d's Avatar
I agree with fcm. If amps are in the truck go to the seat belt bolts. Clean the metal b4 you ground it and use ONE point.
Old Apr 25, 2005 | 11:51 PM
phayzeone's Avatar
Default Re: How to ground 2 amplifiers? (n1mr0d)
sounds good! thanks for the help
Old Apr 26, 2005 | 11:16 AM
Bbasso's Avatar
I have two amps and they share the same bolt in the trunk, use the same guage wire for both and keep the wires short as posible.
Old Apr 26, 2005 | 01:16 PM
bigapple427's Avatar
Default Re: How to ground 2 amplifiers? (Bbasso)
you really should ground the seperatly, if they are grounded together you could get noise. i may be new to the h t forum but have been install car audio for 7 years. so i hope i can help.
Old Apr 26, 2005 | 04:49 PM
Dougs96SI's Avatar
Default Re: How to ground 2 amplifiers? (bigapple427)
Last time i hooked up a system that included two amps I grounded them separately, and it worked fine.
Old Apr 27, 2005 | 08:39 PM
Electrodynamic's Avatar
Added resistance from a 1" x 2" dist. block? Minimal to the extent that you will never notice a difference in voltage. And always ground to the same point.
Old Apr 29, 2005 | 04:35 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigapple427 &raquo;</TD></TR><TR><TD CLASS="quote">you really should ground the seperatly, if they are grounded together you could get noise. i may be new to the h t forum but have been install car audio for 7 years. so i hope i can help.</TD></TR></TABLE> Over 30 years grounding amps at diff. points is what can cause a ground loop. 94
Old Apr 29, 2005 | 04:38 PM
fcm's Avatar
fcm
Old Fart
Default Re: (Electrodynamic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Electrodynamic &raquo;</TD></TR><TR><TD CLASS="quote">Added resistance from a 1" x 2" dist. block? Minimal to the extent that you will never notice a difference in voltage. And always ground to the same point.</TD></TR></TABLE>Yea maybe when you first hook it up, but check it 6mo. later, after the connections have had time to oxidize a bit. 94
Old Apr 29, 2005 | 07:07 PM
CooBlueDAB's Avatar
Default Re: (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">Yea maybe when you first hook it up, but check it 6mo. later, after the connections have had time to oxidize a bit. 94</TD></TR></TABLE>
good point, with oxidization in mind.. is it a good idea to resand/clean off our grounds seasonally?
Old Apr 29, 2005 | 07:12 PM
showtime23's Avatar
Default Re: (CooBlueDAB)
doubtful though. I did add a new bolt to my ground though.
Old Apr 30, 2005 | 07:38 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CooBlueDAB &raquo;</TD></TR><TR><TD CLASS="quote">
good point, with oxidization in mind.. is it a good idea to resand/clean off our grounds seasonally?</TD></TR></TABLE>If term. are soldered to the wire, and the term is bolted down, [tight connection] there should be no need to clean the contact points. 94
Old Apr 30, 2005 | 07:43 AM
all8280bcc's Avatar
Default Re: (fcm)
I use distribution blocks and they work just fine had em in my monte carlo my hatch and my truck never had to clean never any problems. Just my$.02
Old Apr 30, 2005 | 10:52 AM
phayzeone's Avatar
Default Re: (all8280bcc)
My brother use to be an installer and I was looking through his stuff. He had a distribution block just lying around. I might as well use it. He also told me to ground from the same spot if I don't use the distribution block
Old Apr 30, 2005 | 12:23 PM
SirRevvs's Avatar
Wrong. And run a ground from the back of your deck and ground at same location of amp ground as well to further reduce the possibility of ground loop. In car stereo industry is referred to as "return ground"
Old Apr 30, 2005 | 05:40 PM
fcm's Avatar
fcm
Old Fart
Default Re: How to ground 2 amplifiers? (SirRevvs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SirRevvs &raquo;</TD></TR><TR><TD CLASS="quote">
Wrong. And run a ground from the back of your deck and ground at same location of amp ground as well to further reduce the possibility of ground loop. In car stereo industry is referred to as "return ground"</TD></TR></TABLE>Mostly done from chassis of HU to chassis of amp, but can cause noise just as much as get rid of it. 94
ps. I always run a "dump ground" from chassis of HU along with the trigger wire, on problem systems, [HU and amp combos that I have had problems with] just in case I need it, [ about 10% of the time] Hate to have to pull it all apart just to run a wire, after its all together, doing set up and testing, only to find I have a little alt. whine.
Modified by fcm at 6:51 PM 4/30/2005
ALDJ253
Mar 11, 2014 03:41 PM
Xathine
Suspension & Brakes
Nov 6, 2008 12:51 PM
Sumslapper
Suspension & Brakes
10
Nov 23, 2007 10:16 PM
GsDAteg
Oct 10, 2007 01:55 PM
loki2323
Audio / Security / Video
Oct 31, 2003 03:44 PM
