"How to" check engine code for non-OBD PR3?
Old Jul 9, 2002 | 04:42 PM
Norcalstoppy's Avatar
Default "How to" check engine code for non-OBD PR3?
Is it same as other obd ECU's? just find the plug and jump it?
jay Kim
Old Jul 9, 2002 | 05:46 PM
bryant's Avatar
Default Re: "How to" check engine code for non-OBD PR3? (AllMotorMonster)
What are you trying to do? Read the ECU codes. If that is it then:
Long Blinks are counted by 10
Short Blinks are counted by 1
Oh yeah and here is a list for ECU codes. http://tech.hybridgarage.com/tech/codes.html
Old Jul 10, 2002 | 03:22 AM
ULTRA911's Avatar
lift up the passenger carpet and read the laser sequence on your ecu. if it's a jdm ecu, you'll have to take out the ecu cover to get to it. 94-up integras & 92-up civic use the jumper.
Old Jul 10, 2002 | 05:16 AM
badCRX's Avatar
New User
Default Re: "How to" check engine code for non-OBD PR3? (ULTRA911)
Yup, pretty much what he said. The little light in the middle of the ecu will give you the codes. Not the dash light.
Old Jul 10, 2002 | 11:02 AM
Default Re: "How to" check engine code for non-OBD PR3? (badCRX)
When the key is in ON position. Is the light supposed to be flashing at all? Am I supposed to jump a connector like OBD I or does it jsut flash?
Thanks a lot for the help, guys.
Jay Kim
Old Jul 11, 2002 | 06:26 AM
REDBARON's Avatar
If only flashes once initially when you turn on the car. After that it should not blink at all unless you are throwing a code. You don't need to jump anything, just put the key to on and look at the light on the Ecu.
efjones9
16
Jun 10, 2009 08:33 AM
jfields06
Dec 27, 2008 06:42 AM
Chris_Bye
Jul 10, 2004 12:10 PM
ludatic
Nov 2, 2003 10:46 PM
frostt3ch
10
Jun 22, 2003 11:09 AM
