How to fix rolling idle
Old Mar 27, 2008 | 10:38 PM
hatchofdoom's Avatar
Default How to fix rolling idle
Honda-tech I have a 94 ex coupe and it idles fine until it gets warmed up. Then when I stop with the car running the idle stumbles. When Im driving it don't happen how do I fix this annoying problem.
Old Mar 27, 2008 | 10:40 PM
SirRevvs's Avatar
Default Re: How to fix rolling idle (hatchofdoom)
So it idles low like it wants to stall? All the time?
Old Mar 27, 2008 | 10:45 PM
Default Re: How to fix rolling idle (SirRevvs)
not stall but its like your bearly stepping on the gas and letting off but Im not touching the gas pedal and its really annoying
Old Mar 27, 2008 | 10:48 PM
I also noticed when it starts doing it, if I turn the heat on full blast and then turn it off it will stop until I drive and stop again and then it will idle funny agian. That only works sometimes though
Old Mar 27, 2008 | 10:58 PM
SirRevvs's Avatar
check your coolant level.
Old Mar 27, 2008 | 11:02 PM
will it do it if the coolant level is to low or to high cause if its to high then thats it cause the person who had it before me filled it till it about over flows
Old Mar 27, 2008 | 11:03 PM
Former User's Avatar
Try cleaning the EACV (IACV) with some carburetor cleaner.
Old Mar 27, 2008 | 11:09 PM
Default Re: How to fix rolling idle (RonJ@HT)
alright I will do both of those first thing in the morning thanks for yalls help
Old Mar 27, 2008 | 11:13 PM
GoldCoin's Avatar
Clean sensors. Air sensors especially. Iacv.throtte body might need clean.
Try checking your timing and adjust if needed
nekoabandoned
11
Jul 2, 2008 11:59 AM
v8killaz
Mar 10, 2008 10:48 AM
RedSix
Oct 26, 2007 05:47 PM
Mr. Eric
Feb 2, 2005 06:16 AM
speed junk1e
May 29, 2004 10:49 PM
