obd2a h22 motor in obd2b car
Old Mar 27, 2008 | 07:02 PM
blackdelslo's Avatar
Default obd2a h22 motor in obd2b car
I have a 98 accord (obd2b)
Im going to use its stock 2.3sohc vtec engine harness on the 96(obd2a) jdm h22a.
The stock engine harness wont work on the prelude distributor, probaly because the harness is obd2b. Can someone point me to a thread that shows how to wire it to work with the prelude distributor?
Also the accords obd2b harness should just plug right into the preludes injectors right?
Other than lengthening everything, that should be it right?
Again I want to run the accords engine harness on the prelude motor using a obd2b - obd1 ecu conversion harness. Modify the distributor plugs and lengthen the wires. Will this work?
I already looked at the h22 swap thread, i think its mainly for obd1 and obd2a cars.
Old Mar 28, 2008 | 10:17 AM
Default Re: obd2a h22 motor in obd2b car (blackdelslo)
bump.
UniqueX707
Nov 24, 2014 11:33 AM
RSR_Mike
Jul 20, 2011 11:19 PM
FunnyVictor86
Dec 28, 2008 04:15 PM
marcusgnf
Apr 22, 2007 04:21 PM
vteghatch
Apr 29, 2004 08:32 PM
