shift boot
Old Jul 9, 2002 | 04:02 PM
civicboy95's Avatar
Default shift boot
Will a ITR shift boot fit perfectly without any modifications on my 95 civic ex coupe? the one with red stitching that is, and Thank you very much
Old Jul 9, 2002 | 04:53 PM
Ya@inlinePRO's Avatar
Default Re: shift boot (civicboy95)
i just read a post bout that recently...some guy said he had to take out he metal squary thing on the itr and put his civic one on....look for a ctr boot...peace
Old Jul 9, 2002 | 05:19 PM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
yeah I put an aftermarket shift boot on my car. you have to take out the metal square thing on the console, however be VERY CAREFUL, as the metal piece is extremely sharp, and I cut my thumb open on it
Man, did that suck!
Old Jul 9, 2002 | 08:41 PM
civicboy95's Avatar
Default Re: shift boot (fnananon)
hmm, i'm confused as to what eve this metal thing is and I still dont know a definite answer. Does anyone know from personal or definite knoweldge which one to get for my 95 civic?
Old Jul 9, 2002 | 09:07 PM
BagelW's Avatar
There is a metal bracket that has teeth on it that holds the shift-boot on. It attaches to the center console. You will have to take your stock shift-boot off of the metal bracket and thread the ITR boot on to it. Just take your stock boot off and you will see what everyone is talking about. It's not hard to do at all.
Old Jul 9, 2002 | 09:17 PM
civicboy95's Avatar
Default Re: shift boot (Bagel Williams)
oh kool. Thank you. So is it hard to replace shift boots? I dont even know where to get started. How do i even take off the stock shift boot? sorry for being so unskilled in this area. BUt i'd appreciate a lot of help. ALso, Williams, do you know for sure that the ITR will fit perfectly in my 95 civic coupe?
Old Jul 9, 2002 | 09:18 PM
civicboy95's Avatar
also, when i purchase a shift boot, what do is all the material i need to get with the shift boot?
Old Jul 10, 2002 | 08:34 AM
BagelW's Avatar
The ITR boot should fit just fine. I know it works on 96 - 00 Civics so I would assume it would work on 92 - 95 Civics as well.
You have to release the shift **** from the shift boot. The shift **** should just unscrew to seperate from the boot. Your shift **** is different from mine because I have an Si. Once you've got the boot loosened you will have to take the center console off. Then you should be able to slide the metal bracket and shift boot out. Once you've got the shift boot off you can replace the ITR boot onto the bracket. Then you just slide the boot back on to the console and that should be it.
But you do realize that the ITR boot does not connect to the shift ****. It just sits there so that the stem shows, so you will probably want to get a better looking shift ****.
Old Jul 10, 2002 | 09:48 AM
bigmouthcivic's Avatar
the boot will just drop right in.. i put one in my 93 ex coupe and one in my friends 94 coupe. i didn;t have to do anything differen. i just took the old one out and put the new one in.
Old Jul 10, 2002 | 01:17 PM
civicboy95's Avatar
Default Re: shift boot (bigmouthcivic)
hey bigmouth, Does the shift stick show alot compare to our stock shift boot?
Type-Spaz
Nov 28, 2012 05:22 PM
toshko321
Aug 14, 2009 10:59 PM
JDMFantasy2k
Feb 16, 2007 08:29 AM
PSU
Jun 27, 2002 02:06 PM
civicboy95
May 7, 2002 06:36 PM
