Instrument Panel Wont Light Up
My cluster wont light up neither will my tail lights or plate lights but thats all on the same fuse. I keep replacing fuses but the seem to blow instantly when i turn on my lights does anyone know whats going on? thanks in advance....
Re: Instrument Panel Wont Light Up (Spade)
a viper 500 alarm which worked perfectly for 2 weeks then this started.. should i check all my wiring for lose connections ?
Re: Instrument Panel Wont Light Up (DelSol808)
Yup.
Check your grounds and make sure they didn't come loose.....take them off sand them and the area they ground to and re-attach.
But, unless it is obvious that one was attached it will not fix the problem.
teggyboy11
05-09-2011 03:31 PM
