should i or should i not buy(b16 sol $1800)?
Old Mar 27, 2008 | 02:36 AM
umair's Avatar
Default should i or should i not buy(b16 sol $1800)?
i was thinking about buying a b16 swapped del sol, the guy is asking 1800 for it. the only problem is that the timing is off by 180 degrees, the vtec wires have not been connected and it needs new lower ball joints(i am not sure on which side). the body is in decent shape, it has a dent on the quarter panel and as a result it started to rust. he said he took of the head to make sure the motor looked fine. i guess when he put the head back on he messed up the timing.he said he didnt want to fix it because if he did he would want to keep the car and he is not in a postion to keep the car. thats the only ting thats stopping me from buying the car because what if the motor it self is bad? i wont get correct compression numbers because the timing is off. the other problem is that i live 4 hours away from the car and if its not what he says it is i am going to waste 8 hours in total.
what questions should i ask him to help make my decision.
what do you guys think, should i get it or should i not get it?
Old Mar 27, 2008 | 04:16 AM
builtbynotorious.com's Avatar
Default Re: should i or should i not buy(b16 sol $1800)? (umair)
the swap it self is worth 2500 now ask yourself why hes selling the whole car for 1800. i think something has tobe wrong especially since the timing is 180 off and hes not trying to fix it. fixing that problem would help make selling the car alot easier. plus being 180 off could mean he bent some stuff.
Old Mar 27, 2008 | 04:18 AM
newby_j's Avatar
Needs More Cowbell
if the cam is 180 out then you are going to have bent valves, if it is the dizzy, it doesn't matter on the compression #'s b/c you have to pull the plugs anyway.
i would be leary of that car
Old Mar 27, 2008 | 05:01 AM
umair's Avatar
i was thinking the cam thing, but he said that he only drove the car one time after the swap because the timing was off.
so i should expect to pay about 500-800 to fix the car?
Old Mar 27, 2008 | 06:22 AM
civiccoupe94's Avatar
Default Re: (umair)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by umair &raquo;</TD></TR><TR><TD CLASS="quote">i was thinking the cam thing, but he said that he only drove the car one time after the swap because the timing was off.
so i should expect to pay about 500-800 to fix the car? </TD></TR></TABLE>
you cant start that engine with it being 180 degrees off timing, if it was that simple, the guy would of just redo the timing and keep the car.
if the swap was good he could of sold it on craigslist for 1500 and sell the shell for 1000. something is definitely wrong with the car
Old Mar 27, 2008 | 07:52 AM
eddie31003's Avatar
if you dont want it i'll buy it
Old Mar 27, 2008 | 09:26 AM
blk92_d16's Avatar
^He's right, if you won't others will. It's worth more than the asking price. Transporting it seems to be the bigger issue here.
Old Mar 27, 2008 | 09:42 AM
boosted92hatch's Avatar
were u at, ill buy it
Old Mar 27, 2008 | 01:38 PM
umair's Avatar
thanks for the advise, i have not made up my mind yet but i will by tommrow.
Old Mar 27, 2008 | 03:42 PM
PhantoM.DA's Avatar
GDD GRAMMAR POLICE
Default Re: (umair)
buy it and tell us what happens
Old Mar 27, 2008 | 04:57 PM
umair's Avatar
i think i am going to end up buying it this weekend.
Old Mar 27, 2008 | 05:35 PM
cashkeith's Avatar
Default Re: (umair)
looks mint id deff pick it up
good look
Old Mar 27, 2008 | 08:19 PM
EKstacy's Avatar
Default Re: (cashkeith)
id get it, but i wouldnt trust it as a DD until all the kinks were worked out.
delsolboi
Apr 27, 2013 05:00 PM
timthebiker
Apr 22, 2011 04:27 PM
89civicb16a1
Mar 8, 2011 07:20 AM
delslowed
Jun 13, 2004 11:55 AM
