N/A or Boost?
Old Mar 26, 2008 | 08:43 PM
civic_66's Avatar
Default N/A or Boost?
Hey guys just wondering what the majority of you prefer. I want to start my motor build, however don't know if I want to go N/A or boost. I currently have a b16a2 in my eg and just purchased a B18C. I've seen some guys put out 225 whp on the gsrs which is extremely impresisive, however I can just slap a turbo on my b16 and make a quick 300 whp with the right set up and a good tune.
What do you prefer?
Old Mar 26, 2008 | 08:55 PM
duefuss's Avatar
Default Re: N/A or Boost? (civic_66)
you know this thread will cause havoc dont you ??? LMAO JK
turbos are fun to drive but require alot of maintence if not set up properly the first time. N/A will last longer if built properly and tuned. my prefrence on the DOHCs is N/A on the SOHCs im partial to turbo but a good built N/A on a SOHC is easy to like also
Old Mar 26, 2008 | 09:00 PM
JEGD16Z6's Avatar
What do you want to use it for?? I like N/A my self, i use my car for autocrossing and some road racing.
Old Mar 26, 2008 | 09:03 PM
civic_66's Avatar
Default Re: N/A or Boost? (JEGD16Z6)
I'm building the car for autocross and solo sprint, however I'd like to go 1/4 mile once and awhile and lay down some steady times.
Old Mar 26, 2008 | 09:06 PM
Mario_D's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_66 &raquo;</TD></TR><TR><TD CLASS="quote">Hey guys just wondering what the majority of you prefer. I want to start my motor build, however don't know if I want to go N/A or boost. I currently have a b16a2 in my eg and just purchased a B18C. I've seen some guys put out 225 whp on the gsrs which is extremely impresisive, however I can just slap a turbo on my b16 and make a quick 300 whp with the right set up and a good tune.
What do you prefer?</TD></TR></TABLE>
Before you do either, check with the sanctioning body on what the specs are for the classes you are targeting.
m-
Old Mar 26, 2008 | 09:08 PM
JEGD16Z6's Avatar
Default Re: N/A or Boost? (Mario_D)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mario_D &raquo;</TD></TR><TR><TD CLASS="quote">
m-</TD></TR></TABLE>
true, if you are worried about what class you will be in i would look into that.
Old Mar 26, 2008 | 09:13 PM
95ProjectEJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JEGD16Z6 &raquo;</TD></TR><TR><TD CLASS="quote">
true, if you are worried about what class you will be in i would look into that. </TD></TR></TABLE>
Yup, no sense in dropping all that money on the motor only to find that the class you want to run will not allow you in it.
I hear running stock Dseries motors for Auto-x is pretty fun
Old Mar 26, 2008 | 09:40 PM
Kelb's Avatar
i drive a b16a myself, in an eh3, i plan to boost.. I have a ton of respect for NA civics, but, i plan to save that experience for the k-swap, after i boost this b16.
Ill just be looking for around 330 whpish, then i plan to move to k series.
if i were you id probably go NA if you're autocrossing, but, i think ill always love boost.
Old Mar 27, 2008 | 04:26 AM
builtbynotorious.com's Avatar
Default Re: (Kelb)
i used tobe all about na but then it started to get harder and harder to beat sti's and evos so i went boost
Old Mar 27, 2008 | 04:57 AM
ryangirl444's Avatar
It all depends on what kind of budget you are on. If you are on a tight budget, say college student living on your own, or just had a new baby or something, I would not recommend boosting. I've seen it twice in the last four months with my friends. they want to boost so bad, that they rush and try to cut corners and get "good deals" and then **** ends up breaking at least every other day.
However, if you have the money/time/patience/discipline to do it right, I think boosting can be pretty BA
Old Mar 27, 2008 | 05:20 AM
Schister66's Avatar
Man U FTW
I love my turbo GSR and wouldn't ever go back to NA, but the choice is going to stem from your goals and the rules for the class you plan on racing in.
If you do decide to turbo, read into the Forced Induction FAQ and you'll learn a lot in short order. Also, just because you its a turbo setup, doesn't mean it has to be a laggy setup unfit for auto x or road course racing. You can tailor a setup to any need.
Good luck with your decision
Old Mar 27, 2008 | 07:26 AM
Ej Girl's Avatar
Default Re: (Schister66)
If planning on doing autoxing and track use, I would go N/A. All the power there when you need it. Turbo isnt bad but you will have to wait for it to spool up. But if you put too much power into your car youll be spinning tires around alot turns in the autox. N/A might not end up being AS fast as a boosted car, but its still not bad if you put alot of work into it and it will still make good 1/4 mile times. Also, N/A is more reliable in the future then a turbo if you dont have it set up right.
Old Mar 27, 2008 | 07:34 AM
civic_66's Avatar
Default Re: (Ej Girl)
Thanks for all of the positive feedback. Looks like I've got a lot of thinking to do. Also an other question: Is boost good for daily driving? Or will there be a lot of breakage.
Old Mar 27, 2008 | 07:51 AM
CiViCBruh's Avatar
whats n/a?
Old Mar 27, 2008 | 08:05 AM
C-187's Avatar
Default Re: N/A or Boost? (CiViCBruh)
Old Mar 27, 2008 | 08:39 AM
j-monster's Avatar
nothing like hearing a good ol blow off valve go off.... but den again... ITB's kick awesome ninja butt!!!
all preference in this one...
Old Mar 27, 2008 | 08:48 AM
blk92_d16's Avatar
If this is your DD, then stick with N/A. But if you're like me and have a second car as a DD, then boost the hell out of the thing! Sohc E85 pwr!
Old Mar 27, 2008 | 09:01 AM
BWek's Avatar
Did you ever get that guy to see that car has no LSD?
That motor was pretty shady you could do a poor man's type R some pistons and cams could get you going pretty good
I think NA would be best for a auto cross setup the power down low would be worth it but you will want an LSD
Old Mar 27, 2008 | 10:40 AM
BryanM.'s Avatar
Resident Gearhead
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CiViCBruh &raquo;</TD></TR><TR><TD CLASS="quote">whats n/a?</TD></TR></TABLE>
Normally Aspirated
Old Mar 27, 2008 | 12:23 PM
wonderB's Avatar
boost all day at 7lbs for a daily
Old Mar 27, 2008 | 12:38 PM
Juan_Mitosis's Avatar
OMG this question again. Someone should start a poll, which posts does H-T get most?
1. IDLE problem questions
2. N/A or Boost
3. What engine should I buy
Anyways, I've heard that boost can last just as long as N/A with very good tuning, and of course maintenance. I believe it could be true, and that it all relies on the tuner, and on driving style. Just choose a WHP goal, and figure out which would be more inexpensive, or which would be more possible regarding the availability of good tuners in your area.
greenman94
Oct 10, 2013 08:19 AM
efnitup4life
Jan 22, 2011 01:04 PM
maxxd97
Oct 7, 2003 05:19 PM
gsrcivict
Dec 21, 2002 04:05 PM
