need help just bought a 97 hx with b16a2 couple problems
Old Mar 23, 2008 | 10:06 PM
dcsports's Avatar
Default need help just bought a 97 hx with b16a2 couple problems
the end link on driver side is messed up do i buy bushings for just one side or both ? and wat could of cause this it has alot of play
BEFORE READING BELOW CHECK ENGINE LIGHT DOES NOT COME ON EVEN THO BOTH PLUGS ARE JUST HANGING NOT CONNECTED TO ANTHING AND YEA THE CHECK ENGINE LIGHT WORKS
and this plug i want to know wat this is it is just hanging ? its near the oil filter
this plug is also just hanging wat is this plug?
Old Mar 24, 2008 | 12:05 AM
dcsports's Avatar
Default Re: need help just bought a 97 hx with b16a2 couple problems (dcsports)
40 veiws no help?
Old Mar 24, 2008 | 01:26 AM
love of the sol's Avatar
What the hell are youre questions? Please try to specify where that bushing is in your first picture. As far as those other two plugs go I'm not sure, if you posted a front shot of the second one I think it might be for the A/C but, again, I'm not 100% sure.
Old Mar 24, 2008 | 06:59 AM
Kasper.'s Avatar
Default Re: need help just bought a 97 hx with b16a2 couple problems (love of the sol)
THE SWAY BAR END LINKS SHOULD BE REPLACED IN PAIRS THEYLL COST LIKE 15 DOLLARS OR SO TO GET NEW BUSHINGS. YOULL GET NEW BUSHINGS/BOLTS AND SLEEVES JSUT GO TO A PARTS STORE AND ASK FOR SWAY BAR END LINKS FOR YOUR YEAR MAKE AND MODEL
IM NOT SURE WHICH PLUGS ARE WHAT FOR SURE AS ITS BEEN AWHILE SINCE I DID ANYTHING WITH A B16 BUT HERES A SIMPLE QUESTION REGARDING THE PLUGS THAT GO TO NOWHWERE HOW DOES THE CAR RUN? CEL ON? RUN ROUGH?
SORRY FOR THE CAPS
Old Mar 24, 2008 | 07:01 AM
Kasper.'s Avatar
Default Re: need help just bought a 97 hx with b16a2 couple problems (Kasper.)
i didnt see that you had siad the cel wasnt on. most likey one sensor is for the map if it was on the intake manifold or firewall youll have to check into that for sure
kecil
10
May 9, 2011 11:35 AM
Mad Third Gear Vtec
Jul 18, 2009 09:02 PM
buyer
Feb 8, 2008 03:20 AM
beat_nut
Jan 11, 2005 01:19 PM
Digitalcivic
Sep 21, 2004 05:00 PM
