small tig torch
Old Mar 23, 2008 | 12:31 PM
turbotypeR@SPEC's Avatar
25 Year Member
Default small tig torch
i have a lincoln precision tig 185 and am in need of a tiny torch for getting in tight spaces such as a collector. what type do you reccomend. i have already searched and haven't found one for my welder yet. it doesn't have to be a whole new torch, just parts for mine that would be more compact. i was just wondering what you guys were using. i saw the small one that weldcraft makes, but it only does 50 amps and i don't even know if it will work with my welder. i usually weld collectors at about 110 amps. has anybody used this torch for really short periods at higher than 50 amps?
Old Mar 23, 2008 | 01:28 PM
damnraz's Avatar
Default Re: small tig torch (turbotypeR@SPEC)
I've used the weldcraft micro tig torch plus board. All I can say is that it looks to be a useful tool but I have a problem with getting enough gas coverage welding anything. As for as other options I wouldn't know, check weldcrafts brochure to see what they have available. If gas coverage is not an issue to you. This thing will do its job, I'm just **** about stuff like that.
Look into the WP-25 Weldcraft flexible neck pencil type torch, looks like it could work well. http://www.weldcraft.com and download the brochure.
Modified by damnraz at 2:38 PM 3/23/2008
Old Mar 23, 2008 | 05:17 PM
25 Year Member
Default Re: small tig torch (damnraz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by damnraz &raquo;</TD></TR><TR><TD CLASS="quote">I've used the weldcraft micro tig torch plus board. All I can say is that it looks to be a useful tool but I have a problem with getting enough gas coverage welding anything. As for as other options I wouldn't know, check weldcrafts brochure to see what they have available. If gas coverage is not an issue to you. This thing will do its job, I'm just **** about stuff like that.
will that one work with my welder? i guess i will call them tommorow
Modified by damnraz at 2:38 PM 3/23/2008</TD></TR></TABLE>
Old Mar 23, 2008 | 05:26 PM
ROTARY's Avatar
have you tried using extra long cups... they sell them for gas lens setups too.
Old Mar 23, 2008 | 07:35 PM
damnraz's Avatar
I actually dont know, I had mines setup on a miller 200 dx, it might be best to call and ask. Try looking for a glass cup instead of ceramic, it might help you see easier when you're in a tight area like that.
Old Mar 24, 2008 | 04:23 AM
25 Year Member
Default Re: (damnraz)
i already have the pyrex cup, but there are places it won't get.
Modified by turbotypeR@SPEC at 1:33 PM 3/24/2008
Old Mar 24, 2008 | 11:00 AM
25 Year Member
Default Re: (turbotypeR@SPEC)
found one. torch and all of the parts sell for about $200:
http://www.weldtec.com/micro%20tig%20torch.htm
Old Mar 24, 2008 | 11:30 AM
dmotoguy's Avatar
dang, that looks handy!!
Old Mar 24, 2008 | 06:45 PM
damnraz's Avatar
lol That's the one I used, you'll run into a problem with gas coverage trust me unless you have a really accurate flowmeter where you can adjust in 1cfm increments
Old Mar 25, 2008 | 11:39 AM
hootiehoo's Avatar
where does the tungsten go
titwack
Welding / Fabrication
11
Oct 14, 2011 08:33 AM
smead
50
Dec 20, 2010 11:16 PM
Def
Oct 5, 2008 06:36 PM
error
12
May 4, 2007 03:53 AM
model x
Feb 15, 2006 01:08 PM
