Help with wiring mpfi
Old Mar 23, 2008 | 02:11 AM
nitewolf's Avatar
Default Help with wiring mpfi
im using 0bd2 injectors and plugs due to i cant find a resistor box. i just dont know how to wire them up without using a resistor box
Old Mar 23, 2008 | 05:48 AM
97grnrs's Avatar
Default Re: Help with wiring mpfi (nitewolf)
i dont know if u can do that. because the original wire from the ecu goes to the resistor box. worse comes to worse just make a resisstor box from radio shack parts
Old Mar 23, 2008 | 11:25 AM
trackfan's Avatar
Default Re: Help with wiring mpfi (97grnrs)
you can't use a resistor box with obd2 injectors - they are saturated. obd0 injectors are just peak&hold, they DO need a resistor box!
Old Mar 23, 2008 | 12:03 PM
dr_latino999's Avatar
Default Re: Help with wiring mpfi (trackfan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trackfan &raquo;</TD></TR><TR><TD CLASS="quote">you can't use a resistor box with obd2 injectors - they are saturated. obd0 injectors are just peak&hold, they DO need a resistor box! </TD></TR></TABLE> <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97grnrs &raquo;</TD></TR><TR><TD CLASS="quote">i dont know if u can do that. because the original wire from the ecu goes to the resistor box.</TD></TR></TABLE>
<FONT SIZE="3">Adding OBD-2 Injectors</FONT>
OBD-0 MPFI W/ Injector Resistor Box
HOW-TO Delete The Box
Old Mar 25, 2008 | 06:52 PM
nitewolf's Avatar
Default Re: Help with wiring mpfi (dr_latino999)
thanks for the help
Old Mar 25, 2008 | 07:04 PM
Clipsed's Avatar
cool I saw someone do this, and was wondering as to why/what the need to do it is?
Adam West
Dec 9, 2005 07:16 AM
ekblacknight
Jun 20, 2005 01:35 PM
MysteryWagon
Jun 17, 2005 04:16 AM
Mr_Bojangles
Jun 18, 2004 09:07 AM
2k1_ITR_0736
Jul 1, 2003 02:45 AM
