replacing wheel studs on a Civic?
Old Jul 9, 2002 | 05:21 AM
TurBoXBirD16's Avatar
Default replacing wheel studs on a Civic?
any help instructions?
is this possible doing it AT HOME??
thanks
where can i find new studs??
[Modified by xbird, 7:21 AM 7/9/2002]
Old Jul 9, 2002 | 03:12 PM
ten_30's Avatar
Default Re: replacing wheel studs on a Civic? (xbird)
You can buy em from honda. They're not expensive, don't remember the price... less than $10.
I'm sure you can do this at home. You will have to take off the caliper, then rotor. Then hammer the stud back through the hub. You might have to pull the hub off to be able to clear the broken stud.
Then you just pull the new stud back through with some lugnuts or something suited for pulling a stud through.
Old Jul 9, 2002 | 03:29 PM
CRX7's Avatar
Default Re: replacing wheel studs on a Civic? (ten_30)
I was able to replace mine without pressing the hub apart, but it took a really big hammer and a lot of force. By the time I got it on the hub came off.
Old Jul 9, 2002 | 07:48 PM
Default Re: replacing wheel studs on a Civic? (CRX7)
haha
ok thanks guys
DIY RULES!!!
cmfnelson
Nov 24, 2012 01:03 AM
Bertsch911
May 18, 2012 06:15 AM
ewoo
Feb 24, 2009 04:23 PM
HCivExoo
Mar 19, 2005 09:05 PM
Tokyo_X-treme_Racer
Jul 20, 2004 08:10 AM
