How to tell if HeaD is Bad.. When Off Block
Old Mar 22, 2008 | 08:13 PM
BiG_DeE's Avatar
Default How to tell if HeaD is Bad.. When Off Block
Whats best way, this guy is getting rid of a z6 head for pretty cheap, and my plan is to swoop it up, but honestly i dont want something that i need to rebuild. its just for my dd but it needs new valve steam seals and cx head = shitty already so any ideas??
Old Mar 22, 2008 | 09:35 PM
EkFG's Avatar
Default Re: How to tell if HeaD is Bad.. When Off Block (BiG_DeE)
ask him to have it check and pay him the diff.
Old Mar 22, 2008 | 10:50 PM
cherroneballs's Avatar
you can check if it's warped by taking a long metal ruler and put it corner to corner on the bottom and make sure it's all flat. but internally just
Old Mar 23, 2008 | 09:56 AM
BiG_DeE's Avatar
bump, but what bout like the valves and such, how do i tell if there bad?? or the seals?? the valve cover is taken off...
Old Mar 23, 2008 | 02:09 PM
JDM Lyfestyle's Avatar
Visually inspect it for corrosion,cracks etc then try putting a long straight edge across it to check for warps as cherroneballs said.
Unless I misunderstood you said it already needs valve stem seals so when you pull it down to replace them you can remove the valves,clean them lap them and replace the seals.
Old Mar 23, 2008 | 02:44 PM
BiG_DeE's Avatar
Default Re: How to tell if HeaD is Bad.. When Off Block (JDM Lyfestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM Lyfestyle &raquo;</TD></TR><TR><TD CLASS="quote">Visually inspect it for corrosion,cracks etc then try putting a long straight edge across it to check for warps as cherroneballs said.
Unless I misunderstood you said it already needs valve stem seals so when you pull it down to replace them you can remove the valves,clean them lap them and replace the seals.</TD></TR></TABLE>
nah my dd car needs valve seals.
dominate9
Apr 14, 2020 02:10 PM
80 dolla crx hf
Sep 8, 2014 01:28 PM
xwhitchx
Mar 26, 2009 02:17 PM
jrod95cpe
11
Feb 12, 2009 09:31 AM
blackeg
Sep 4, 2003 07:23 PM
