LS/VTEC Oil Passage?
Old Mar 22, 2008 | 04:20 PM
libral00's Avatar
Default LS/VTEC Oil Passage?
I know there is a way to make an oil passage for the Vtec on an LS block but im not sure how. Any ideas??
Old Mar 23, 2008 | 08:23 AM
stealthmode62's Avatar
Default Re: LS/VTEC Oil Passage? (libral00)
Hook a hose up to the backside of the head via the oil pressure sender. It's pretty well documented.
Old Mar 23, 2008 | 08:44 AM
libral00's Avatar
Default Re: LS/VTEC Oil Passage? (stealthmode62)
I know how to do it externally, but im asking about an internal way?
Old Mar 28, 2008 | 05:24 AM
JohnnieChimpo's Avatar
I've heard of people doing it but during a recent search I found a pic showing an LS block compared to a VTEC block. The deck on the VTEC has more material where the oil hole is. The LS block doesn't have material in that location so it isn't as simple a drilling a hold for the oil to come up. I guess you could have someone weld in a chunk of aluminum so that it could be drilled or if you were building one of those tall deck plate engines you could do it. It doesn't seem like there is an easy way except to use an external line.
Old Mar 30, 2008 | 09:57 AM
libral00's Avatar
Default Re: LS/VTEC Oil Passage? (JohnnieChimpo)
I bought my car 6 years ago with an ls/vtec setup with no external oil line, but I don't have the old block anymore so I have nothing to compare it to. damnit.
Sylverius
Jun 20, 2003 11:04 PM
drumking15
May 14, 2003 10:06 AM
B16A1-EF9
Dec 7, 2002 03:27 PM
WAFFLES
Jul 20, 2001 02:23 PM
