need to know how to wire a distributor!!!
Old Mar 20, 2008 | 06:31 PM
dirtylilhonda's Avatar
Default need to know how to wire a distributor!!!
does anyone know where i can find out how to wire a 95 obd I distributor to a 96 obd II car that is ran from a obd I ecu. that sounds confusing i know.
Old Mar 21, 2008 | 01:15 PM
SikB's Avatar
Default Re: need to know how to wire a distributor!!! (dirtylilhonda)
The second post under "Poison's OBD1 ~> OBD2 distributor Diagram" - https://honda-tech.com/zerothread/650329
Old Mar 21, 2008 | 03:13 PM
Default Re: need to know how to wire a distributor!!! (SikB)
THANK YOU SO SO SO MUCH!!!!!!!
Old Mar 21, 2008 | 08:06 PM
well there is a problem... thats for a h22 into a civic. my wires aren't matching up with it. i have like 3 different. but it helps .
Old Mar 21, 2008 | 08:41 PM
mgags7's Avatar
check the "hybrid" forum down below on the honda-tech main page. There is a thread about swapping h22s into civics there that has all the info you need.
Old Mar 22, 2008 | 12:03 PM
Default Re: (mgags7)
no i'm sorry i must be saying the wrong thing. i have a 96 prelude. h23. i put a 95 h23 back in it. i used my 96 harness and a jumper harness with an obd I ecu. i now have to use a obd I dizzy. i need to know how to wire the obd I dizzy to my 96 obd II harness. i know i have to use the wires that were going to my crank postion sensor for the cam postion in the dizzy but i'm not sure which wire goes where i was hoping that some has done this and could help me with that. the link that he posted on here was for a h22 into a civc so the wires don't exactly match mine.
Old Mar 22, 2008 | 05:51 PM
mgags7's Avatar
use that thread, the wiring is the same.
Old Mar 22, 2008 | 08:09 PM
when i was looking at it and my car there were like 2 or 3 that didn't match the diagram. they are differnet colors. is that for a internal coil or external?
Old Mar 22, 2008 | 08:54 PM
mgags7's Avatar
whoops I forgot to mention that.
Your car will not need to be wired to change to external coil, because it already is.
The only wires you should have to deal with are the 4 for the 2 added sensors.
Old Mar 23, 2008 | 11:04 AM
i don't have the dizzy yet but your saying all the wires are the same except the sensors that are in it. right? which i can run from the crank sensor? right?i found someone on here that has done this exact swap before but i can't catch him online. do you know jdmlude5? i'm jus not too good with wiring.
J-Brooks
Jan 16, 2006 08:56 PM
Gonzo
May 13, 2003 04:22 PM
dominate9
Nov 1, 2002 06:43 AM
Gonzo
Sep 3, 2002 06:31 AM
