would a cut O2 wire cause a short?
my car has been having charging issues, and today as i was looking around i saw that my primary O2 sensor's black wire is cut. its not all the way cut but more than halfway. could that possible cause a short even tho its not touching anything?
no, but id fix that use some electric tape for a temp fix, then id go through and look a t everything else, what kinda short is it?? whats the main thing that is bein effected by this short?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BiG_DeE »</TD></TR><TR><TD CLASS="quote">no, but id fix that use some electric tape for a temp fix, then id go through and look a t everything else, what kinda short is it?? whats the main thing that is bein effected by this short?</TD></TR></TABLE> the car doesnt charge. ive changed alt, battery, ELD, all teh grounds, checked all the fuses and the wiring.....
im lost
im lost
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkankyEJ7 »</TD></TR><TR><TD CLASS="quote">One of my friends cars had the O2 wires melt on his header and it cause it hold a charge, BUt it was touching the header.</TD></TR></TABLE>
ill change the sensor tonight! anyone know how i can check the think wire on the alternator to make sure it has connection?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evil Smile »</TD></TR><TR><TD CLASS="quote">my car has been having charging issues, and today as i was looking around i saw that my primary O2 sensor's black wire is cut. its not all the way cut but more than halfway. could that possible cause a short even tho its not touching anything?</TD></TR></TABLE>
if the wires in the black wire is exposed and is touching anything... it will cause it to short.
same thing happened to me... i had an aftermarket header and had to lengthen the wires to the 02 sensor and the heat from the header melted the tape and the outter layer of the wires and when ever the exposed wire touched metal or anything it would blow a fuse.
jus fix the wire and keep it away from anything hot.
thanks alot guys, the wire is exposed but doesnt appear its touching anything. im gonna change it tonighta nd really hope it puts an end to my problems. cause this probelm has been going on for 3 weeks now and my DD is just sitting in the garage!!!!!!!
here is my other thread about the whole proble if you guys want to comment on it. thanks ina dvance
https://honda-tech.com/zerothread?id=2239570
