need check engine light codes !
0 ECU - Electronic Control Unit http://b16a2.kicks-***.net/diy...0.gif
1 O2A - Oxygen sensor #1 http://b16a2.kicks-***.net/diy...1.gif
2 O2B - Oxygen sensor #2 http://b16a2.kicks-***.net/diy...2.gif
3 MAP - Manifold Absolute Pressure sensor http://b16a2.kicks-***.net/diy...3.gif
4 CKP - Crank Position sensor http://b16a2.kicks-***.net/diy...4.gif
5 MAP - Manifold Absolute Pressure sensor http://b16a2.kicks-***.net/diy...5.gif
6 ECT - Engine Coolant Temp sensor http://b16a2.kicks-***.net/diy...6.gif
7 TPS - Throttle Position Sensor http://b16a2.kicks-***.net/diy...7.gif
8 TDC - Top Dead Centre sensor http://b16a2.kicks-***.net/diy...8.gif
9 CYP - Cylinder Position sensor http://b16a2.kicks-***.net/diy...9.gif
10 IAT - Intake Air Temperature sensor http://b16a2.kicks-***.net/diy...0.gif
12 EGR - Exhaust Gas Recirculation lift valve http://b16a2.kicks-***.net/diy...2.gif
13 BARO - atmospheric pressure sensor http://b16a2.kicks-***.net/diy...3.gif
14 EACV - (IAC) - Electronic Air Control Valve http://b16a2.kicks-***.net/diy...4.gif
15 IOS - Ignition Output Signal http://b16a2.kicks-***.net/diy...5.gif
16 INJ - Fuel Injectors http://b16a2.kicks-***.net/diy...6.gif
17 VSS - Vehicle Speed Sensor http://b16a2.kicks-***.net/diy...7.gif
19 ATLC - Automatic Transmission Lockup Control Valve http://b16a2.kicks-***.net/diy...9.gif
20 ELD - Electrical Load Detector http://b16a2.kicks-***.net/diy...0.gif
21 VTS - VTEC Spool Solenoid http://b16a2.kicks-***.net/diy...1.gif
22 VTP - VTEC Pressure valve http://b16a2.kicks-***.net/diy...2.gif
23 KS - Knock sensor http://b16a2.kicks-***.net/diy...3.gif
41 PO2H - Primary Oxygen Sensor Heater http://b16a2.kicks-***.net/diy...1.gif
42 SO2H - Secondary Oxygen Sensor Heater http://b16a2.kicks-***.net/diy...2.gif
43 FSS - Fuel Supply System http://b16a2.kicks-***.net/diy...3.gif
Enjoy
Modified by Lukezen_27 at 8:08 AM 3/21/2008
Enjoy
followthadollar
11
05-03-2010 04:21 PM
sshonda2004
10
07-12-2005 01:55 PM
