please help still no spark
i posted about 2days ago i tried everthing i have a 92 honda prelude si jdm h22. when it was running it use to just die on me so what i have changed so far is the ignition coil, fuel filter, main relay and i cleaned the ground on the thermostat i have no clue any other suggestions :
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acidcrakker »</TD></TR><TR><TD CLASS="quote">
What about the ignition on the steering column. I forget what exactly is faulty on there, but Im sure some else knows better than I what that part is. </TD></TR></TABLE>
Ignition switch, pull it out and take a look at it. You can either resolder it or buy a new one.
Is it even cranking over? If it is and you're not getting spark the only thing u have left to rule out is the ignitor. If it doesn't even crank over your problem lies elswhere.
It is called the ignition switch and if it runs and shuts off going down the road or just sitting there it could be that part.
Sounds like the ignition switch, the electrical piece behind the part you put your key in. I have replaced quite a few of them on different hondas to fix that very problem.
twotonecivic
Apr 24, 2009 09:48 PM
