duration/lift question??
Old Mar 20, 2008 | 06:29 AM
dcomer04's Avatar
Default duration/lift question??
newbie on here... i've had the opportunity to get camshafts for my b16 from a guy who says they are "type r" specs....
he gave me this:
CENTERLINE : 16.05 BTDC
INTAKE: Duration 237.17 @ 0.060 inches LIFT: 0.5583 in
EXHAUST: Duration 256 @ 0.050 inches LIFT: 0.494 in
i don't think it's the same as a "type r" cam but would it be okay for a turbo application??
thanks..
Old Mar 20, 2008 | 06:51 AM
crazyguy's Avatar
Default Re: duration/lift question?? (dcomer04)
that spec is not oem itr or ctr cams spec and thats very aggresive cams. your engine wont idel normal and it will tick and tap alot. i hope u have stronger valve springs and retainers built. and the spec that u provided is the cheap cams that he bought from ebay, i think they are made by xs power or something
i am trying to find the oem spec itr or ctr cams for you cause 00-01 usdm ITR shares the same cams as JDM EK9 CTR cams
the link below is CTR EK9 oem cam spec
http://www.tprmag.com/issue/2/truth_fiction.shtml
Modified by crazyguy at 8:00 AM 3/20/2008
Modified by crazyguy at 8:10 AM 3/20/2008
Old Mar 20, 2008 | 07:00 AM
BryanM.'s Avatar
Resident Gearhead
Default Re: duration/lift question?? (crazyguy)
Once again, crazyguy is correct!
Old Mar 20, 2008 | 07:47 AM
dcomer04's Avatar
thanks crazyguy....
i do have titanium valves and retainers but if it's too agressive (i would still like to daily every once in a-while) then i won't buy them.....you happen to know where i can get a good set of ctr or itr cams????
thanks,
Old Mar 20, 2008 | 07:53 AM
crazyguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dcomer04 &raquo;</TD></TR><TR><TD CLASS="quote">thanks crazyguy....
thanks,</TD></TR></TABLE>
this is where i get my 00-01 ITR cams from and once again. only 00-01 ITR cams have same spec as JDM EK9 CTR's . you wont and cant go wrong with oem honda parts. and as long as u dont rev over 8000rpm. you can reuse your stock b16a valve springs and retainers.
after the cams are installed, u might want to get it dyno tuned, to get precise fuel/air raito. and remember to do the valve adjustment. if u dont know how to do the cams swap. pm me. i wil teach u
http://www.hondapartsunlimited.com/
CrAzyGsR101
Apr 21, 2004 10:25 PM
AllMoToRB18c
Oct 26, 2003 02:33 PM
Chalupa R
Dec 1, 2002 11:21 PM
498GSR
Oct 28, 2002 10:06 PM
EJ8 Kenobi
Oct 23, 2002 05:01 PM
