lower control arm
got into an accident and bent the driver side lower control arm...ok i took all the bolts out but when it came down to the last bolt (the bigger side NOT the ball joint side) where it bolts onto the actual car... the bolt broke inside is there a way i can unbolt and replace what the control arm is bolted to cause i see bolts but its kinda a big black piece of metal... PLEASE HELP FAST its my only car....
I am guessing that you broke the bolt/capture nut that is welded inside the front subframe. You have 2 options 1st is to open up the subframe under where bolt goes through and weld a nut in place then close the subframe back up. The 2nd option is to replace the entire lower front subframe but they are very expensive around $350.
if the sway bar was bent you will need to get a new one.
that bolt is just spinning? yeah you probablly just snapped the welded nut inside the subframe off. you dont need to replace the entire subframe but you can if you want.
what i did when this happened to me when i was trying to put on n H brace was if you look at where the welded nut would be there is alread a predrilled hole underneath it on the subframe. cut a larger square out. get a 17 or 19 mm wrench in there and get the bolt and nut out.
get a new bolt from honda and go to HD or Lowes and get a m10 or m12x1.25 i believe nut. and just do a nut and bolt combo. add thread locker and ur done. did it with my full suspension hatch which i beat on and its lasted 2 yrs no problems.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6civic1538 »</TD></TR><TR><TD CLASS="quote">so i can unbolt the whole cross member and put a new one on cause i need a new sway bar too....Right??</TD></TR></TABLE>
yeah you can replace the whole subframe, IDK about $350, maybe new. i find it easier to just replace the frame. hit up a junk yard and pull it off yourself, you'll save alot of money.
PrettyMuchBoned
Apr 22, 2014 07:33 PM
allums34
Apr 13, 2011 09:55 AM
thi3v3z
Jun 18, 2009 10:16 AM
