Transmission help.
Old Jul 8, 2002 | 06:20 PM
CRXGSR's Avatar
Default Transmission help.
Can someone help me identify the gears in the transmission. I got the tranmission and supposedly the 1st gear synchro is bad, but I don't know what's what. Please identify what you can in the photo. Thanks.
BTW, pic is a YS1
Old Jul 8, 2002 | 06:59 PM
seekerONE's Avatar
Default Re: Transmission help. (CRXGSR)
#1-5th gear..countershaft
#2-4th gear..countershaft
#3-3rd gear..countershaft
#4-2nd gear..countershaft
#5- 1st/2nd selector hub<includes synchros and reverse gear..countershaft>
#6- 1st gear countershaft
#7- 5th/reverse selector hub<includes synchros>
#8- 5th gear..mainshaft
#9- 4th gear..mainshaft
#10- 3rd/4th selector hub<includes snychros>
#11- 3rd gear..mainshaft
#12- 2nd gear..mainshaft<this is part of mainshaft casting>
#13- reverse gear..mianshaft<this is part of mainshaft casting>
#14-1st gear..mainshaft<this is part of mainshaft casting>
#15- final drive ring gear..differential
[Modified by seekerONE, 4:00 AM 7/9/2002]
Old Jul 9, 2002 | 03:35 PM
CRXGSR's Avatar
Thanks for all your help. Just a few more questions. If I wanted to change a gear, do I have to change both the countershaft gear and the mainshaft gear? Also, if I need to replace a synchro, what part to I change?? The tranny you are looking at is a spare, but I have another one that has a bad 3rd gear synchro. Do I change the "brass" gear on the synchro (#10 in picture)??
Old Jul 9, 2002 | 10:01 PM
sleeper4dr's Avatar
that depends on what you're doing.... if you are for example, swapping your stock 5th for an LS 5th, then YES you would need both main shaft and counter shaft gears. otherwise the gears would not fit together because the gears are different sizes and have a different # of teeth as well.
if you were just replacing your stock gear for another stock gear, then the answer is NO.
the 'synchros' that most people refer to are the BRASS RINGS like you said. but if at all possible, it would be a good idea to replace the synchro HUB and SLIDER/SLEEVE because the teeth on these pieces are just as important as on the brass rings, and they wear out as well.
hth
Jason
MySiIsRed
Transmission & Drivetrain
Jun 5, 2013 10:22 AM
jasonp
Feb 25, 2009 08:12 PM
blackccoupe
Oct 28, 2003 01:10 AM
Cyber ITR
Jul 22, 2001 07:50 AM
