d16z6 and i want to turbo it how much boost can i run
Old Mar 18, 2008 | 04:42 PM
hotxcivic92's Avatar
Default d16z6 and i want to turbo it how much boost can i run
d16z6 stock internals
Old Mar 18, 2008 | 05:58 PM
luvmihatch's Avatar
Default Re: d16z6 and i want to turbo it how much boost can i run (hotxcivic92)
0 lbs. we use jet engines now.. lots more power and no lag...
hit the search button helps alot.. ftw
but id say 6=8 if ur not gonna be boost happy
Old Mar 18, 2008 | 06:32 PM
z6hatchboy's Avatar
all depends on the turbo and a/r. But for the normal ebay t3/t4 no more than 8psi 10 maybe, but thats pushing it a little.
Old Mar 18, 2008 | 06:33 PM
Hybrid96EK's Avatar
Default Re: d16z6 and i want to turbo it how much boost can i run (z6hatchboy)
I ran 8psi daily on stock internals (tuned of course) through a 19T greddy kit. Did 10psi here and there and occasionally 14psi.
Old Mar 18, 2008 | 06:39 PM
mypreludeissexy's Avatar
Default Re: d16z6 and i want to turbo it how much boost can i run (Hybrid96EK)
Would it be worth running about 5 or 6 psi on stock internals because I can get a turbo kit that someone is selling for about a grand. I just don't want to blow the motor because it has high mileage. I just want a little more hp that I/H/E can't offer and it's pretty cheap. Just a question, no flaming please...
Old Mar 18, 2008 | 06:44 PM
i just want 4to 6lbs and that all nothing more daily driver just a little more power you no by anyway you no what i mite need if i have a intercooler pipping waistguage blowoff valve what else do i need
Old Mar 18, 2008 | 06:53 PM
97ekb18b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotxcivic92 &raquo;</TD></TR><TR><TD CLASS="quote">i just want 4to 6lbs and that all nothing more daily driver just a little more power you no by anyway you no what i mite need if i have a intercooler pipping waistguage blowoff valve what else do i need</TD></TR></TABLE>
you should go check this out!!!!!!!
https://honda-tech.com/zerosearch
oh and i ran 7 psi on my mini me and it blew in 2 weeks!
Old Mar 18, 2008 | 06:59 PM
95sloweg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotxcivic92 &raquo;</TD></TR><TR><TD CLASS="quote">what else do i need</TD></TR></TABLE>
your gonna need more knowledge about boosting a motor. unless you have money to drop in another motor in case you blow the current one boosting it, then i would not boost it right away.
Old Mar 18, 2008 | 07:18 PM
Default Re: d16z6 and i want to turbo it how much boost can i run (95sloweg)
yea i have a b16 with a built head just need money right now and i have a d16 and iam getting a turbo kit for it soon just want a little more power really just want 4lbs of boost really no more
Old Mar 18, 2008 | 08:19 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotxcivic92 &raquo;</TD></TR><TR><TD CLASS="quote">yea i have a b16 with a built head just need money right now and i have a d16 and iam getting a turbo kit for it soon just want a little more power really just want 4lbs of boost really no more
4lbs is worthless. run 8. Its not going to die assuming its in good health right now and you have it tuned. It a LOT more exciting on 8lbs. It will make you wonder why you invested in that B16.
Old Mar 18, 2008 | 08:59 PM
ke98248's Avatar
I'm tuned with a 168K d16y8 motor all stock internals except ARP head studs/new oem head gasket ON a garrett t3/t4 turbo .57 trim .63 AR on 10PSI.. Been running fine for 4 months strong.
[b]My point is -- d-series motors will last a long time with GOOD tune and GOOD turbo brand parts if it's fairly healthy to begin with. A quick leak down and compression test will reveal important details about the health of your motor. On a general note -- I'd run no more than 14 psi on a t3 turbo and 10 psi on a t3/t4 turbo, and like 6 psi on a t4 turbo (NOT recommended)
Old Mar 18, 2008 | 09:01 PM
K i l l a B e e.'s Avatar
Default Re: d16z6 and i want to turbo it how much boost can i run (ke98248)
10lbs. Get a compression test. If it turns out good, and you want to daily drive it with some ***** behind it, 8-10psi is good. You'll net at around 200whp. with a average turbo.
Old Mar 29, 2008 | 02:57 PM
luvmihatch's Avatar
Default Re: d16z6 and i want to turbo it how much boost can i run (K i l l a B e e.)
yo mac.. just get a lil turbo and run 8 lbs ill help u install the turbo kit. only bc i live down the street from u..and ur gonna buy my oil retun line setup.. i swing by 2morrow and fig out what u wanna do... no ebay ****.. lol..
Old Mar 29, 2008 | 04:35 PM
hatchnideas's Avatar
you tune for hp not psi. d series, usually, you top out at 220-240 on a stock bottom end with a good tune and a healthy engine.
Bipolarcivic
Aug 7, 2013 05:36 AM
XanderTurbo88
Oct 31, 2008 06:01 PM
jdmdseries
Nov 26, 2007 07:28 PM
SOHC_TURBO_CIVIC
Aug 26, 2003 06:20 AM
xcivic_ex
Feb 10, 2002 09:19 PM
