Header wrap question
Old Mar 17, 2008 | 07:50 PM
E.Honda's Avatar
Default Header wrap question
How many feet will I require to wrap one DC header?
Any tips or tricks would be nice. I did hear that you soak it in water before wrapping. Have yet to comfirm this.
If anyone has some black header wrap for sale ...let me know.
Thanks
E.Honda
Old Mar 17, 2008 | 08:17 PM
egsleepercivic's Avatar
I don't have any tips or tricks, but I don't think you want to soak it in water. it will trap moisture in there and cause the header to corrode prematurely
gl
Old Mar 17, 2008 | 09:15 PM
E.Honda's Avatar
Default Re: (egsleepercivic)
Story I was given was that when it dried it shrank up slightly making it real tight fit and easy to manage.
Old Mar 17, 2008 | 09:31 PM
Default Re: (E.Honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by E.Honda &raquo;</TD></TR><TR><TD CLASS="quote">Story I was given was that when it dried it shrank up slightly making it real tight fit and easy to manage.</TD></TR></TABLE>
yeah I don't have a personal expierence with it but the things I have read about involved the wrap retaining moisture and rusting headers faster, to me it seems like a give take relationship, your header may rust a lil quicker, but your engine bay will stay cooler.
gl
Old Mar 18, 2008 | 08:25 AM
E.Honda's Avatar
anyone
Old Mar 18, 2008 | 07:01 PM
inspyral's Avatar
The amount of wrap you'll need will depend on your particular header, but it's a good idea to buy an extra roll in addition to what you think you'll need. Most manufacturers will give you an estimate on how many linear feet you'll need based on the diameter of your primaries. Yes, it is recommended to soak the wrap in water before hand, both to make it more pliable and easy to work with, and to reduce the discomfort of working with fiberglass. I've never noticed if the wrap shrinks afterwords, but then again, I've never put it on dry. Any moisture in the wrap will burn off during the first heat cycle. You might also want to consider using a spray-on coating that most manufacturers offer in order to prolong the life of the wrap. Be sure to get enough ties/clamps for the number of tubes you're wrapping. I've always used the strap style fasteners, and they've always worked well for me. I've never used the snap clips, but they seem harder to use. Some people also use common hose clamps, although their width may make it hard to get into tight spaces or bends. Also, be prepared for a nice smell when you start the car for the first time.
Old Mar 18, 2008 | 08:15 PM
E.Honda's Avatar
Default Re: (inspyral)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral &raquo;</TD></TR><TR><TD CLASS="quote">The amount of wrap you'll need will depend on your particular header, but it's a good idea to buy an extra roll in addition to what you think you'll need. Most manufacturers will give you an estimate on how many linear feet you'll need based on the diameter of your primaries. Yes, it is recommended to soak the wrap in water before hand, both to make it more pliable and easy to work with, and to reduce the discomfort of working with fiberglass. I've never noticed if the wrap shrinks afterwords, but then again, I've never put it on dry. Any moisture in the wrap will burn off during the first heat cycle. You might also want to consider using a spray-on coating that most manufacturers offer in order to prolong the life of the wrap. Be sure to get enough ties/clamps for the number of tubes you're wrapping. I've always used the strap style fasteners, and they've always worked well for me. I've never used the snap clips, but they seem harder to use. Some people also use common hose clamps, although their width may make it hard to get into tight spaces or bends. Also, be prepared for a nice smell when you start the car for the first time.</TD></TR></TABLE>
Thanks.
The header is a DC header on a b16a2.
I never heard of this spray coating though....Any idea on what it is called?
Old Mar 19, 2008 | 12:34 AM
inspyral's Avatar
http://store.summitracing.com/...earch
Old Mar 21, 2008 | 09:22 PM
E.Honda's Avatar
Default Re: Header wrap question (E.Honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by E.Honda &raquo;</TD></TR><TR><TD CLASS="quote">How many feet will I require to wrap one DC header?
Thanks
E.Honda</TD></TR></TABLE>
Old Mar 22, 2008 | 07:21 AM
gibsanez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egsleepercivic &raquo;</TD></TR><TR><TD CLASS="quote">
gl </TD></TR></TABLE>
I don't understand how an exhaust manifold that operates at like 800 degrees can trap moisture.
Old Mar 22, 2008 | 07:26 AM
Padawan's Avatar
Darth ModerVader
I would highly suggest leaving it unwrapped or having it professionally coated.
Old Mar 22, 2008 | 07:38 AM
gibsanez's Avatar
Default Re: Header wrap question (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">I would highly suggest leaving it unwrapped or having it professionally coated. </TD></TR></TABLE>
Howcome?
Old Mar 27, 2008 | 06:18 PM
Padawan's Avatar
Darth ModerVader
Default Re: Header wrap question (gibsanez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gibsanez &raquo;</TD></TR><TR><TD CLASS="quote">
Howcome?</TD></TR></TABLE>
Because the exhaust wrap can damage the header or reduce its lifespan, while a proper professional coating (inside and out) will actually protect the header, extend its life, and reduce underhood temperatures.
Old Mar 28, 2008 | 01:51 AM
gibsanez's Avatar
Because the exhaust wrap can damage the header or reduce its lifespan, while a proper professional coating (inside and out) will actually protect the header, extend its life, and reduce underhood temperatures. </TD></TR></TABLE>
What about the wrap will reduce the lifespan?
edit - nvm, found a half decent link
http://www.centuryperformance.....html
Old Mar 28, 2008 | 05:50 AM
Flashmn's Avatar
Moisture would boil out when the manifold gets hot.
What the problem is, with carbon steel (most non stainless manifolds etc) will burn out the carbon due to higher temperatures and you will get what is called thermal corrosion.
Doesnt affect heavy gauge tube headers that much.
I'm using wrap because of hoses and stuff that go near the turbo manifold. Thus I'd like to have some additional security.
Old Mar 28, 2008 | 07:48 AM
rogue55.rm's Avatar
I had a stainless steel 4-2-1 header that I wrapped about a year ago. About a month ago, I started hearing an exhaust leak comming from the front of the engine. I thought it was the header gasket at first, since I had reused it like three times. Anyways, after changing the gasket the leak was still there. It turns out that the wrap had kept so much heat in the headers that the welds where the primaries come together had cracked all the way around. It would have been much louder had the wrap not muffled it some. I got my brother to MIG weld it back together. If you plan on wrapping your headers, you must take into consideration the affects it will have on the lifespan of the header, welds in particular. If you have a mild steel header, like the DC sports Ceramic coated headers, this will be worse and happen much sooner.
Old Mar 28, 2008 | 08:20 AM
steven_highet's Avatar
Default Re: (rogue55.rm)
I wrote this article for this topic.
Heat is the back bone of your engine making power with out it your engine would be a big paper weight. Been able to harness the heat in you engine is a great way to improve power, VE and overall efficiency of your engine. This is why the tuning of A/F ratio has such an impact on power. It all has to do with the increase of heat inside the combustion camber. The leaner the A/F mix the hotter it is going to be. Obviously to lean is bad! But you get what im trying to say. When the spark plug ignites the A/F mixture in the cylinders it is the rapid increase in heat which causes the pressure rise in the cylinder which in turn pushes the piston down. 1/3 of the heat generated is used to create work to rotate you crank, 1/3 of the heat is dissipated into the piston crown, cylinder walls and cylinder head and the last 1/3 is expelled out your engine through the exhaust, That is the beauty of a turbo charger been able to harness the 1/3 of wasted heat and turn it into power. The more heat that is trapped in the correct places the more power you can make.
Ceramic Coatings
For instance, Ceramic Coatings on the piston tops, valves, turbo exhaust
housing, manifold and downpipe, intake manifold, boost piping are great ways to stop heat from dissipating off or into these components. Coatings on your turbo parts will increase turbo spool as there is more heat to generate more work on the exhaust turbine. Coatings on your piston tops and valves will increase the amount of heat expelled out your exhaust system due to the fact that less heat will be absorbed into the metal which in turn again creates more spool on the turbo. It also allows you to run closer piston to bore clearance due to less heat in the piston and less expansion of it. Coating the inside and outside of the intake manifold and using a hondata intake gasket is another great way to improve power. As im sure we all know cooler air is denser which is good for making more power. The reason for this is that when the denser air mixes with the fuel and is ignited the air and fuel molecules are packed closer together which allows for a more stable burn rate and better flame propagation. Then on the other side of the scale if you have a hot intake charge when the fuel is mixed with the air it will evaporate into smaller droplets thus increase the burn rate of the A/F mix when ignited. Fast burn rates can become unstable very quickly! Basically you want the A/F charge to burn slowly and steadily from the center of the combustion chamber to the combustion chamber walls. If not there is an increased chance of detonation and pre-ignition. I have seen tests done on completely stock engines ceramic coating certain components and increasing horsepower by 8%– 12% you take that to your 400HP turbo motor and you are looking at 40 – 50hp plus the added benefit of decreased under hood temps, intake temps, component wear, corrosion resistance, fuel economy.
Heat Wraps
And yes you should wrap your manifold and downpipe and get a turbo heat bag for the exhaust housing. The downside to wrapping these components is the increased
corrosion it will create due to it trapping water. Ceramic coating is the better option but I guess it’s what your wallet can afford. I could go on about this subject for ever. It basically boils down to the basics of controlling heat, making it go where you want it to and keeping it away from what you want it not to get to. There are so many little simple things people, can do to improve the thermodynamics of there engines if they just look at there setup and think about it!! There are plenty books that are dedicated to this topic which can be found under thermodynamics of an internal combustion engine. Well I hope you enjoyed this article. More to come!!
Old Mar 28, 2008 | 12:02 PM
gibsanez's Avatar
Default Re: (steven_highet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steven_highet &raquo;</TD></TR><TR><TD CLASS="quote">I wrote this article for this topic.
Please explain how you trap water against a manifold that operates at like 800 degrees, unless you wash your engine bay down with the hose every night or something
Old Mar 28, 2008 | 12:45 PM
Default Re: (gibsanez)
Yeah but your manifold isn’t constantly at that temperature. Yeah when it is there will be no water on it for sure. It’s the other time in between that is the problem. You gonna tell me just cause a manifold operates at a high temp that it doesn’t corrode? Now im talking about the long term effect heat wrapping can have on your manifold. If you were to take a stock manifold, a heat wrapped manifold and a ceramic coated manifold and run then like that for a year believe me the heat wrapped one would look the worst outta all of them!
Old Mar 28, 2008 | 02:19 PM
gibsanez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steven_highet &raquo;</TD></TR><TR><TD CLASS="quote">Yeah but your manifold isn’t constantly at that temperature. Yeah when it is there will be no water on it for sure. It’s the other time in between that is the problem. You gonna tell me just cause a manifold operates at a high temp that it doesn’t corrode? Now im talking about the long term effect heat wrapping can have on your manifold. If you were to take a stock manifold, a heat wrapped manifold and a ceramic coated manifold and run then like that for a year believe me the heat wrapped one would look the worst outta all of them!</TD></TR></TABLE>
I completely agree that header wrap is bad, i even posted a link explaining why.
What i don't agree with, is the "moisture" thing. OK, obviously you are correct in saying that your manifold isn't constantly at that temperature.
But if it's not at that temperature, that must mean you aren't driving, right? Well if you aren't driving your car, how is your header supposed to get wet? Do you have a hood?
Old Mar 28, 2008 | 03:09 PM
KENetics1's Avatar
But if it's not at that temperature, that must mean you aren't driving, right? Well if you aren't driving your car, how is your header supposed to get wet? Do you have a hood?</TD></TR></TABLE>
when it rains outside your header can still get wet even if you aren't driving. Like the morning dew or fog. Or just moisture in the air caused by the rain and/or hot weather. In wisconsin during the summer it is super humid outside unlike in arizona or nevada where it's hot but dry. You get that feeling like your ***** are glued to your boxers because it's so god damn moist and humid outside.
Modified by KENetics1 at 6:39 PM 3/28/2008
Old Mar 28, 2008 | 06:25 PM
gibsanez's Avatar
Default Re: (KENetics1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KENetics1 &raquo;</TD></TR><TR><TD CLASS="quote">
So the theory is that fog/dew/humid weather is what's ruining wrapped headers? I'm sorry, but that's a really weak theory.
Read the link I posted. It makes WAY more sense than the idea of fog rotting out wrapped manifolds.
Old Mar 28, 2008 | 07:01 PM
gibsanez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KENetics1 &raquo;</TD></TR><TR><TD CLASS="quote">i don't know if it would ruin a header either i was just trying to state how moisture could get in the header wrap without actually coming into contact with water.</TD></TR></TABLE>
If a header was wrapped tight enough, the minuscule amount of moisture that got in wouldn't make a bit of difference, compared to the damage the extra heat does.
Thanks for the idea of where the mystery moisture is coming from though
Header wrap does not "trap moisture" and cause headers to rust out. OK people? IT's NOT THE MOISTURE, IT'S THE HEAT
Old Mar 28, 2008 | 07:17 PM
KENetics1's Avatar
woops accidently deleted my post instead of editing. I was just trying to add that reading about the step header design was a good read on the same page.
Old Jun 20, 2010 | 09:59 AM
MrLeWayne's Avatar
This thread answered alot of my questions concerning heat wrap. Thanks to everyone who contributed!
d16Booger
29
Mar 4, 2009 05:19 PM
Capo dei Capi
Dec 6, 2007 08:06 PM
ericstambaugh07
May 27, 2007 06:15 PM
kornerk12
May 26, 2007 10:10 AM
608 Gangsta
12
Apr 2, 2006 11:09 PM
