need help from some engine builders
Old Mar 15, 2008 | 05:23 PM
superfast666's Avatar
Default need help from some engine builders
ok to start of it a ls b18b1 stock completley rebuilt new bearings new rings new gaskets new water pump oil pump and so on. my problem is i had it assembeled and they and come to find out the cylinders were not honed and when i started the motor it ran perfect then i go to start it again and smokes like a bitch there is blow by in the cylinders my question is if i take it all apart and have the cylinders bored within the service limit can i reuse the rings and if i do will they seat properly
Old Mar 15, 2008 | 10:08 PM
civicstar's Avatar
Default Re: need help from some engine builders (superfast666)
i usually never reuse rings even after a simple start, usually if u let it idle for about 20 mins it will start to seat and then the perfect A/F will allow for a good break in after that, but just get some new ones
Old Mar 16, 2008 | 02:22 PM
Default Re: need help from some engine builders (civicstar)
anyone else think i would be ok with the same rings
Old Mar 16, 2008 | 05:49 PM
PolishSasquatch's Avatar
if all you did was just start it and run for a couple minutes, im pretty sure you can just reuse them
Old Mar 16, 2008 | 06:03 PM
KENetics1's Avatar
did you forget to have the cylinders honed or did the machine shop forget to do it?
Old Mar 16, 2008 | 08:22 PM
Default Re: need help from some engine builders (KENetics1)
now im not sure because im only getting blow by in 2 cylinders im gonna pull the pistons and see if the rings are staggered correctly does any one know if u can get blow by if the rings are positioned at the pin or thrust surface
Old Mar 17, 2008 | 09:53 AM
riceburner700's Avatar
if you bore/hone your cylinders your piston ring gaps are gonna be off. as cheap as rings are just get another set
blackcrx16
17
Sep 18, 2007 10:45 PM
1991hb
Jan 2, 2007 11:55 PM
HYBRID_H@TCH
Jun 11, 2004 07:48 PM
TURBO-JET LUDE
May 7, 2003 10:06 AM
fastludeh22
Sep 24, 2002 12:47 AM
