sportlines and camber kit...
yo, i have an '07 si coupe and am planning on installing some eibach sportlines on it (stock 17" wheels). question is, how critical is it for me to install a camber kit? if it's a must, do i just need it for the front? can someone post a link of a good and inexpensive camber kit?
also, can you guys post some quick pics of your coupes with the sportlines? i've ran the pro-kit in the past on my iroc-z and mustang gt but i thought now it's time to step it up (or down in this case
) to the sportlines; i'm just worried about the car grinding on stuff.
after these are installed will i also need an alignment?
thanks for all your help fellas!
) to the sportlines; i'm just worried about the car grinding on stuff.after these are installed will i also need an alignment?
Yes you will need an alignment.
As for a camber it, no you don't 'need' one. However, you WILL get excessive tire wear and you'll need to rotate your tires frequently (every 3k-ish miles) to avoid this. In the end, it's just more cost-effective to get a camber kit.
