flip switch
I need alittle help wiring a flip switch.
its one of those led ignited flip switchs with 3 terminal connections on it.
question is i donno which wire goes where. says led, 12volt.. n ground but not sure which one is wiitch.
and there is 3? why 3.. should there just be ground n power..
any help would be great if anyone knows how.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nickoz »</TD></TR><TR><TD CLASS="quote">should there just be ground n power..
any help would be great if anyone knows how.</TD></TR></TABLE>
Only if you want to switch a short circuit.
You're hopefully switching a 12 volt source to go somewhere, so that's 2 terminals (1 in and 1 out). The ground is needed to light the LED. That"s the 3rd terminal.
As for which ones are for what, I have no clue. Did the package have a diagram on it? It's simple enough to figure out, but in your case, I would suggest you get someone to help you before you burn something up.
96 GSR-T
May 7, 2011 08:24 PM
