instal question
Old Feb 5, 2005 | 02:04 PM
dabrat8614's Avatar
Default instal question
i want to install a turn on/off switch i have the switch it has three prongs on back i want to use it to turn on/off my amp how do i hook it up?
Old Feb 5, 2005 | 02:35 PM
shawn_crx's Avatar
Default Re: instal question (dabrat8614)
3 prongs switch is basically a switch with light.
If you want the light to turn on when the switch is on.
Then 1 switch is Ground.
If you don't want the light, then just use 2.
There should be a drawing on the switch. but if not just used a tester and test it.
Old Feb 5, 2005 | 08:12 PM
rawkus's Avatar
Shawn is right, about the wiring of the switch, but I will elaborate a bit more.
1 prong is Positive, wire that into a power connector that is only on when the key is in ACC or ON.
2 prong is Switched, wire this into the amps remote connection.
3 prong is Ground, wire that to bare metal.
This way the amp will only come on when the switch is on AND the key is in the ignition.
Dan
Old Feb 6, 2005 | 06:58 AM
fcm's Avatar
fcm
Old Fart
Default Re: instal question (rawkus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rawkus &raquo;</TD></TR><TR><TD CLASS="quote">Shawn is right, about the wiring of the switch, but I will elaborate a bit more.
Dan</TD></TR></TABLE> What if its just a SPDT switch? 94
Old Feb 6, 2005 | 10:20 AM
rawkus's Avatar
Default Re: instal question (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> What if its just a SPDT switch? 94</TD></TR></TABLE>
Can you explain that a lil bit? Thanks.
Dan
Old Feb 6, 2005 | 11:59 AM
fcm's Avatar
fcm
Old Fart
Dan</TD></TR></TABLE>SPDT= single pole double throw or a switch tha has 3 "prongs" on it, were middle "prong" is common and the 2 outside "prongs" are connected with middle depending on what way you toggle the switch 94
Old Feb 6, 2005 | 12:21 PM
rawkus's Avatar
I dig, thanks for the info.
Dan
Dazer 1991
Aug 27, 2012 03:26 PM
eL_cArLos
Feb 20, 2008 06:19 PM
SigmaOmega
Jul 17, 2005 06:55 PM
HondaGuRu
Audio / Security / Video
10
Jul 23, 2003 09:05 AM
Pengo
Mar 17, 2002 10:05 AM
