trouble with my 96 civic ex
Old Mar 12, 2008 | 07:27 AM
jlopez88's Avatar
Default trouble with my 96 civic ex
ok this is the problem i just sent my car to a guy to get my d16 y8 built from the bottom up these are the specs stock crank, stock rods, p29 pistons, hastings rings, all new bearings, whole gasket set, crower ti springs and retainers, crower stage 2 cam, new aftermarket water pump, walbro 190 psi fuel pump, 310 injectors, and phearable ecu. ok wel i got my car back last weekend and its started over heating about halfway home i limped it home and put a new thermostat in it and it still didnt fix it. the mechanic had it towed back to his house and replaced the head bolts and that didnt fix it he said the only thing he could think of is it being the head so he sent the head to a machine shop to check it i havent heard anything back from him yet so i just was goin to see what everyone else thinks about it
Old Mar 12, 2008 | 07:36 AM
2redstars's Avatar
did you/he bleed the coolant system? make sure the fan is kicking on?
Old Mar 12, 2008 | 07:39 AM
jlopez88's Avatar
Default Re: (2redstars)
yeah man they were all checked
Old Mar 12, 2008 | 07:43 AM
jlopez88's Avatar
Default Re: (jlopez88)
like it only started overheating when the motor reached operating temperature and then the coolant started boiling out of the overflow tank
Old Mar 12, 2008 | 08:02 AM
2redstars's Avatar
did you try a new radiator cap?
Old Mar 12, 2008 | 08:05 AM
skateboard_ej8's Avatar
im hench irl
i dont think your fan is working. make sure that sensor ontop of the thermostat housing is working. They tent to stop woring after a while.
k90n90w
15
Aug 29, 2014 10:21 AM
ERIC1
22
Oct 6, 2010 09:33 AM
hondamike89
Feb 28, 2009 01:40 PM
koa
Feb 16, 2008 09:27 PM
BlackGSR
May 29, 2002 01:39 PM
