Si cluster into 99 Dx speedo problem
Old Mar 11, 2008 | 09:24 PM
kaboomwoom's Avatar
Default Si cluster into 99 Dx speedo problem
I recently bought a Si cluster over the internet. I installed it into my car with no prior problems because I was sick of not having a tach. After I installed it and turned the ignition to the "on" selection, the speedometer jumped to 18 mph. Is it a faulty cluster? is it the car? does the cluster need to be calibrated?
Old Mar 11, 2008 | 09:41 PM
H22Ej1's Avatar
Shenanigans
Default Re: Si cluster into 99 Dx speedo problem (kaboomwoom)
does the mph seem to increase normally as you drive it? if so i think your needle is off
Old Mar 11, 2008 | 09:52 PM
BlueIntegraBoy's Avatar
Could be a faulty cluster. Like H22 asked, does the speed increase from 18 MPH?
Old Mar 11, 2008 | 10:07 PM
kaboomwoom's Avatar
Default Re: Si cluster into 99 Dx speedo problem (H22Ej1)
yeah the needle increases from 18pmh. how would i calibrate that?
Old Mar 11, 2008 | 10:25 PM
H22Ej1's Avatar
Shenanigans
if it increases like normal but zeros at 18 i say remove the needle and drive along side a friend at say 30 or something and slap the needle back on. cruise around some more and make sure its accurate. or have a shop calibrate it and youll know its correct
Old Mar 11, 2008 | 10:27 PM
x0!'s Avatar
x0!
have your cluster ready to come out. turn the key when it goes to 18mph disconnect the cluster. put the needle back to 0. reconnect and see what happens
Old Mar 12, 2008 | 12:04 AM
p10hlm's Avatar
Default Re: (x0!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x0! &raquo;</TD></TR><TR><TD CLASS="quote">have your cluster ready to come out. turn the key when it goes to 18mph disconnect the cluster. put the needle back to 0. reconnect and see what happens</TD></TR></TABLE>
somebody sold you a rigged cluster.
whats up x0, another houstonimports/jspek member here
Old Mar 12, 2008 | 01:05 AM
68minik20R's Avatar
Old Mar 12, 2008 | 01:06 AM
68minik20R's Avatar
1999jdm
11
Apr 17, 2013 04:22 AM
BIGef
Jan 27, 2012 12:06 PM
aziaticvang
Jan 8, 2008 06:41 PM
killerB16A
Aug 15, 2007 10:56 PM
