Si cluster into 99 Dx speedo problem
I recently bought a Si cluster over the internet. I installed it into my car with no prior problems because I was sick of not having a tach. After I installed it and turned the ignition to the "on" selection, the speedometer jumped to 18 mph. Is it a faulty cluster? is it the car? does the cluster need to be calibrated?
Re: Si cluster into 99 Dx speedo problem (kaboomwoom)
if it increases like normal but zeros at 18 i say remove the needle and drive along side a friend at say 30 or something and slap the needle back on. cruise around some more and make sure its accurate. or have a shop calibrate it and youll know its correct
Re: (x0!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x0! »</TD></TR><TR><TD CLASS="quote">have your cluster ready to come out. turn the key when it goes to 18mph disconnect the cluster. put the needle back to 0. reconnect and see what happens</TD></TR></TABLE>
somebody sold you a rigged cluster.
whats up x0, another houstonimports/jspek member here
1999jdm
11
04-17-2013 04:22 AM
