irratic idle need help ASAP video inside!!!!
i have a 97 ej8 with a b18b swap it idles really ruff and struggles in first and second, i have no idea were to start i just got done rebuilding it and now this, the only cel is for the iacv which when i hook it up makes the car idle at 4000 rpms, please help this is my dd and it is running like ****!!!
http://youtube.com/watch?v=8CLoX461UMg
bumo i just went out and rechecked the dizy firing order and it was wrong i fixed that it idles good now now it just is lacking power im assuming the cams are off alil, and i do have a vacuum leak do you think that would cause it to have low power and pop back threw the intake alil bit...
do you think if i timed the crank by using a screw driver in the num1 cylinder but i was turning it clock wise and not counter clock wise it would throw the timing off one tooth and cause it to lack power.....
its currently unhooked dont you guys read the thread.... if i hook it up i idle at 4000 rpms, i have know idea as to what to check i can not figure it out....
make sure you don't have the connector for iacv switched with another from the harness, some sensors share the same clips and i think (but i'm not sure) the iat sensor is one of them.
my car threw a cel and idled like **** when i had these switched around, the tps and map sensor connectors can also be switched around ....
i tryed swithching the tps and map around and it idled fine then if i gave it gas it back fired bad also i am only throwing a code for the iacv which is not hooked up, if the plug was wrong for the ias im sure it would throw a code to......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97ekb18b »</TD></TR><TR><TD CLASS="quote">i tryed swithching i am only throwing a code for the iacv which is not hooked up</TD></TR></TABLE>
? iacv is not hooked up, how do you expect it to idle if it isn't sending anything to the ecu? Did you build a blockoff plate for the iacv or is it just hot plugged in?
crxspoonb18c5
Jun 18, 2008 02:21 PM
allshownogo
Mar 9, 2008 08:46 AM
