irratic idle need help ASAP video inside!!!!
Old 03-11-2008, 06:25 PM
97ekb18b's Avatar
Default irratic idle need help ASAP video inside!!!!
i have a 97 ej8 with a b18b swap it idles really ruff and struggles in first and second, i have no idea were to start i just got done rebuilding it and now this, the only cel is for the iacv which when i hook it up makes the car idle at 4000 rpms, please help this is my dd and it is running like ****!!!
http://youtube.com/watch?v=8CLoX461UMg
Old 03-11-2008, 07:01 PM
97ekb18b's Avatar
Default Re: irratic idle need help ASAP video inside!!!! (97ekb18b)
bumo i just went out and rechecked the dizy firing order and it was wrong i fixed that it idles good now now it just is lacking power im assuming the cams are off alil, and i do have a vacuum leak do you think that would cause it to have low power and pop back threw the intake alil bit...
Old 03-11-2008, 07:14 PM
97ekb18b's Avatar
do you think if i timed the crank by using a screw driver in the num1 cylinder but i was turning it clock wise and not counter clock wise it would throw the timing off one tooth and cause it to lack power.....
Old 03-11-2008, 07:17 PM
mikeforan's Avatar
probably a sensor.
Old 03-11-2008, 07:28 PM
97ekb18b's Avatar
Default Re: irratic idle need help ASAP video inside!!!! (mikeforan)
what sensor.....
Old 03-11-2008, 09:35 PM
97ekb18b's Avatar
please help
Old 03-12-2008, 11:23 AM
YELLOW_DUCK's Avatar
iacv. see if it's pluged in all the way. that might bee your issue tho
Old 03-12-2008, 06:30 PM
97ekb18b's Avatar
Default Re: (YELLOW_DUCK)
its currently unhooked dont you guys read the thread.... if i hook it up i idle at 4000 rpms, i have know idea as to what to check i can not figure it out....
Old 03-12-2008, 07:01 PM
thursday's Avatar
make sure you don't have the connector for iacv switched with another from the harness, some sensors share the same clips and i think (but i'm not sure) the iat sensor is one of them.
my car threw a cel and idled like **** when i had these switched around, the tps and map sensor connectors can also be switched around ....
Old 03-12-2008, 07:05 PM
97ekb18b's Avatar
Default Re: (thursday)
i tryed swithching the tps and map around and it idled fine then if i gave it gas it back fired bad also i am only throwing a code for the iacv which is not hooked up, if the plug was wrong for the ias im sure it would throw a code to......
Old 03-12-2008, 07:08 PM
thursday's Avatar
Default Re: (97ekb18b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97ekb18b &raquo;</TD></TR><TR><TD CLASS="quote">i tryed swithching i am only throwing a code for the iacv which is not hooked up</TD></TR></TABLE>
? iacv is not hooked up, how do you expect it to idle if it isn't sending anything to the ecu? Did you build a blockoff plate for the iacv or is it just hot plugged in?
Old 03-13-2008, 06:32 PM
97ekb18b's Avatar
yea its not plugged in because when it is it idles at 4000 rpms constent so do you think this might be why it idles funny........
josejdm
09-15-2009 12:08 PM
joshuma
09-02-2008 05:37 AM
crxspoonb18c5
06-18-2008 02:21 PM
allshownogo
03-09-2008 08:46 AM
1stealthls
05-21-2002 06:11 PM
Quick Reply: irratic idle need help ASAP video inside!!!!
