4" Aluminum Exhaust Question
Old Mar 11, 2008 | 01:16 PM
dmotoguy's Avatar
Default 4" Aluminum Exhaust Question
I can get 30, 60, or 90 degree bends.. with 6",10",or 12" radius..
What do typical eg's need, its a drag only car and isnt streeted.. do I even need bends or is it pretty easy to do w/ pie cuts.
Old Mar 11, 2008 | 03:07 PM
RS2 FAB's Avatar
Default Re: 4" Aluminum Exhaust Question (dmotoguy)
why aluminum? it's more expensive, harder to weld (you can only GMAW and TGAW it,
and you p[robably could not GMAW aluminum piping becuase of it's thickness (too thin).
pie cuts create more work for you, you can do a straight back design but what are you going to do........we need more info on what you want out of your setup, not waht a typical eg takes becuase you could have a side exit,
straight pipe, half an exhuast. we don't know what muffler you're going to run ETC
Old Mar 11, 2008 | 04:03 PM
onefstek's Avatar
for an eg you will need the 6" radius or smaller.
mid pipe you will need : one 90* and two 45*
over the lca part you will need : four 45* or two 90*
Old Mar 11, 2008 | 04:30 PM
dmotoguy's Avatar
Default Re: (onefstek)
cool thanks. I'll order the al and report back.
I could mig it, I do thinner at work all the time, but tig would look nice. I searched all day for a photo of a straight back system but could not find one. Like I stated in my original post, its a drag only car.. Never streeted, so I might do straight back
Old Mar 11, 2008 | 04:55 PM
onefstek's Avatar
this is full straight trough pipe kit that I have. not sure if that is what you are looking for.
Old Mar 11, 2008 | 06:31 PM
k24em2's Avatar
Default Re: 4" Aluminum Exhaust Question (RS2 FAB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RS2 FAB &raquo;</TD></TR><TR><TD CLASS="quote">why aluminum? it's more expensive, harder to weld (you can only GMAW and TGAW it,
straight pipe, half an exhuast. we don't know what muffler you're going to run ETC </TD></TR></TABLE>
4" aluminum tube is way cheaper than 4" stainless tube
Old Mar 12, 2008 | 03:03 AM
No Dig's Avatar
Default Re: 4" Aluminum Exhaust Question (k24em2)
why alum? weight?
Old Mar 12, 2008 | 03:07 AM
RS2 FAB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k24em2 &raquo;</TD></TR><TR><TD CLASS="quote">4" aluminum tube is way cheaper than 4" stainless tube</TD></TR></TABLE>
why not MS?
Old Mar 12, 2008 | 05:15 AM
tepid1's Avatar
why not MS? </TD></TR></TABLE>
Rust....
Old Mar 12, 2008 | 07:36 AM
k24em2's Avatar
Default Re: 4" Aluminum Exhaust Question (tepid1)
and weight....
global tech has 4" aluminum tubing in 16 ga for $3.50 a foot, and 90 degree mandrel bent elbows for $19.20 each
Old Mar 12, 2008 | 07:47 AM
onefstek's Avatar
yes weight.
my aluminum pipe kits weight in at 10lbs. where the steel version is 35lbs.
Old Mar 12, 2008 | 08:41 AM
KENetics1's Avatar
Not mine but if it's a race car why not straight pipe all the way back like this 4" aluminum exhaust.
Old Mar 12, 2008 | 08:56 AM
dmotoguy's Avatar
Default Re: 4" Aluminum Exhaust Question (KENetics1)
Might do it that way... I'm new to fabricating stuff like this, I'm trying to do pretty much every part for my car though, its a fun learning experience.
I just ordered from global tech, $150 shipped for (2) Straight 4ft sections (3) 90's and (2) 45's.
Old Mar 12, 2008 | 09:07 AM
onefstek's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KENetics1 &raquo;</TD></TR><TR><TD CLASS="quote">
Not mine but if it's a race car why not straight pipe all the way back like this 4" aluminum exhaust.</TD></TR></TABLE>
Unless he plans on taking his fuel tank out, he will have to go the oem route.
Old Mar 12, 2008 | 10:01 AM
tony1's Avatar
Default Re: 4" Aluminum Exhaust Question (onefstek)
Stock tank is still in in those pics. Mine runs the same way, with the stock tank there.
Old Mar 12, 2008 | 04:50 PM
manifoldmiketyson's Avatar
Default Re: 4" Aluminum Exhaust Question (tony1)
i did two daily driven supras with .120 wall 6061 tube. pie cuts. its been a couple months with no problems.
i cut the pies on a mitre saw. take about 15 minutes to cut 3 90's worth. total cost would be around $100(pipe only). only expensive thing is the aluminum v-bands. welding takes more time, but with the thick wall, you can run beads pretty quick and still get a great finish.
youngs performace = $60 with or without o-ring
if its a race car only, i would use .063 wall 6061 which can be had just about anywhere. you want to keep your radius tight.
global techs radius =
Old Mar 18, 2008 | 08:24 AM
dmotoguy's Avatar
Default Re: 4" Aluminum Exhaust Question (manifoldmiketyson)
I need (1) 4" aluminum v-band and (1) 4" Stainless v-band.. who do you guys reccomend?
Old Mar 18, 2008 | 10:55 AM
paulzy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dmotoguy &raquo;</TD></TR><TR><TD CLASS="quote">I need (1) 4" aluminum v-band and (1) 4" Stainless v-band.. who do you guys reccomend?</TD></TR></TABLE>most places allow you to mix and match material.
Old Mar 18, 2008 | 11:55 AM
dmotoguy's Avatar
Default Re: 4" Aluminum Exhaust Question (paulzy)
I need one for the downpipe and one for the muffler..
Verocious Motorsports has the vibrant ones, they are $68 for alum and $88 for stainless.. anyone know if thats the best deal available?
Old Mar 18, 2008 | 12:00 PM
paulzy's Avatar
http://www.quicktimemotorsport...at=31
http://www.youngsperformance.c...20267
Old Mar 18, 2008 | 12:25 PM
dmotoguy's Avatar
Default Re: (paulzy)
thanks!
b18cya94
Welding / Fabrication
24
Mar 26, 2013 05:41 AM
90Rexx
May 18, 2010 02:27 PM
.adam.
Jul 31, 2006 09:19 AM
E-Rok
Nov 3, 2002 09:37 PM
Smashback
Mar 18, 2002 05:22 PM
