Weird ignition problem. SEARCHED
I was having a terrible spark related problem. The higher I revved, the more intense it got. Anyways I needed to change spark plugs anyways. Did. Its still there. TODAY I started testing for arching n stuff, and found out that my spark plug wires are apparently doing great. When I accidentally touched the ignition screew thats on top with a screwdriver, I got one hell of a shock. I placed it near again, and sparks where arching from the screw to the screwdriver when I would ground the screwdriver against a wire. To further test, I grounded a piece of cable on the chassis and touched the screw again, big time spark. Is there any way i can open up the ignition and fix/solder whatever thing is lose and causing this? Thanks for the help!
Cliff notes
- Spark archs from an ignition screw when touched by a grounded source.
- Want to fix this thing myself, as in open up the ignition and fix whatever wire is grounding around wrong.
THANKS!
EDIT: Ok I believe I've got this all wrong. Its not the ignition, but the DISTRIBUTOR what I'm talking about. I'm sorry for the misinformation, english is not my first language!
Modified by Juan_Mitosis at 10:55 PM 3/10/2008
Cliff notes
THANKS!
i can help u but i just dont understand what the problem is man,,, i mean what is ur car doing???? those sparks u were talking about dont seem like a problem to me any car will do that
s2kkk
20
Apr 15, 2004 11:12 AM
