o2 sensor problem...........need help please
Old Mar 10, 2008 | 06:33 AM
jdm1980's Avatar
Default o2 sensor problem...........need help please
i just put a d16b in my civic and the plug for the o2 sensor is not fitting.the new sensor on the motor is 1-wire.the cars harness is a 4-wire.the ecu is a p08 that i got with the motor.that ecu doesnt require a 4-wire o2 sensor.i took the old sensor off the old motor(4-wire)just so i would have something.but the check engine light comes on and i checked it and im getting code 1.any help will be appreciated thanx.
Old Mar 10, 2008 | 07:04 AM
IIXtremeHansen's Avatar
Default Re: o2 sensor problem...........need help please (jdm1980)
You will need an O2 that matches your ECU your using. Also your O2 might be damaged. its always good to replace with a new one. I had used an old one but get a CEL untill i replaced with a new one and CEL went away.
Old Mar 10, 2008 | 08:13 AM
jdm1980's Avatar
Default Re: o2 sensor problem...........need help please (Dickies_n_FlipFlops)
i still need to know what to do about the wiring.i have the 4-wire o2 hooked up now but when i go to put in the 1-wire o2 it doesnt fit the plug on the cars wiring harness.do i just cut those 4-wires and splice my 1-wire o2 into the white wire on the harness and forget about the rest or do i have to do something else.another ?,can i use the 4-wire and just eliminate the other wires.kinda tight on $ right now.thanks
rsangha13
Mar 31, 2013 07:18 AM
NightHawkBlack-R
Feb 16, 2009 10:28 AM
moosepoop21
May 10, 2007 12:30 PM
efyou
May 26, 2006 09:27 AM
anothersickhatch
May 15, 2004 10:22 PM
