Question about valve adjustment procedure
Old Jul 7, 2002 | 07:17 PM
Chubz's Avatar
Default Question about valve adjustment procedure
I noticed to different instructions on to where the feeler gauges are to be poistioned. On C-Speed.com it was between the cam lobe and lifter, on Bseries.net the feeler guage seemed to be between the valve retainer and the jamnut. Anyone with info? I might be doing this on my own and would like some info to help me out. I will have a helms manual also.
Old Jul 7, 2002 | 07:19 PM
MrBite's Avatar
Default Re: Question about valve adjustment procedure (SuperTech)
All the times I've done it/seen it done it was between the cam lobe and lifter. Pretty sure that's what it shows in the helms, too.
Old Jul 7, 2002 | 07:25 PM
Chubz's Avatar
Thats what im seeing also. So all i do is place the feeler gauge between the cam lobe and lifter for each valve.
Old Jul 8, 2002 | 03:13 AM
BudMan's Avatar
I'll gladly verify the procedure - the last thing on bseries we want to do is give out bad info! For what it's worth - I've done the adjustments on all my Honda's the same way (including my R that now has 91,000 miles running hard!!). So don't get too worried that your motor will fall apart doing it the other way.
I'll post what I find & correct any mistakes as quickly as I can.
jeff
Old Jul 8, 2002 | 07:10 AM
sgT's Avatar
sgT
Default Re: Question about valve adjustment procedure (BudMan)
you will be WAY off if you are on the valve stem
Factory specs state the valve lash should be measured
betweeen the rocker and the lobe. The rocker arm ratio is
around 1.55:1 so unless you factor that into your lash
adjustment you are gonna be off.
Old Jul 8, 2002 | 07:20 AM
Eric R's Avatar
Default Re: Question about valve adjustment procedure (sgT)
So, can someone give some good pointers of how to do it right???
I will do this by my own in the near future too.
To hell with the dealer...
Eric - who haven't send his R to the dealer not even once.
Old Jul 8, 2002 | 12:22 PM
BudMan's Avatar
Well, I never cease to amaze myself as to how little I know. At least I don't mind admitting I'm wrong
I think I'll be doing a few free valve jobs in the near future
Old Jul 8, 2002 | 12:30 PM
B18C5's Avatar
I believe on the D series motors you adjust just under the jam nut. At least that's what I remember doing... I don't know if it's right. When I got the R I was very worried cuz I couldn't reach under the jam nut with my feeler gauges, so I just measured between the lifter and cam lobe. I assume that's the right way to do it.
Old Jul 8, 2002 | 12:31 PM
yoshi234's Avatar
I shoot brides
nice avatar steve
vtec.dc2
Nov 29, 2006 01:58 AM
silentblackhat
Dec 27, 2004 06:49 PM
ORcivicsi
Jul 17, 2004 12:37 PM
SpoogenJay
Aug 9, 2003 01:37 PM
White Lightnin
Mar 10, 2003 09:30 AM
