VALVE LASH?????
Old Jul 15, 2004 | 11:20 PM
ORcivicsi's Avatar
Default VALVE LASH?????
Wanting to do a valve lash adjustment. Searched couldn't find what i need.Does ne one have pictures of where the feeler gauge slips in between the valve and the lifter? Im confused.
Old Jul 15, 2004 | 11:23 PM
ORcivicsi's Avatar
Default Re: VALVE LASH????? (ORcivicsi)
Help
Old Jul 15, 2004 | 11:58 PM
vteczone's Avatar
slip the feeler gauge between the lifter and the cam lobe.
Old Jul 16, 2004 | 05:37 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (vteczone)
On the DOHC engines, I slip the feeler gauge between the lifter and cam lobe by starting between the camshafts. You can do either side, but that side seems to work a little easier.
Old Jul 17, 2004 | 08:25 AM
ragerized's Avatar
for a valve lash adjustment, youre going to need some feeler guages, 12mm wrench, and a flathead screwdriver. slip the feeler guages between the lifter and the cam with the cam lobes pointed up, you'll have to turn the engine a few times as you go along. you loosen the bolt that has a little flathead inside, and you turn the flathead right for less clearance, and left for more. hope this helps
Old Jul 17, 2004 | 12:37 PM
accorse07's Avatar
Default Re: VALVE LASH????? (ragerized)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ragerized &raquo;</TD></TR><TR><TD CLASS="quote">for a valve lash adjustment, youre going to need some feeler guages, 12mm wrench, and a flathead screwdriver. slip the feeler guages between the lifter and the cam with the cam lobes pointed up, you'll have to turn the engine a few times as you go along. you loosen the bolt that has a little flathead inside, and you turn the flathead right for less clearance, and left for more. hope this helps </TD></TR></TABLE>
you also need to rotate the cams and set it tdc and start with cylider # 3 than 2 than 1 than four...after each cylinder is done make sure to turen the crankcounter clockwise a 1/4 turn and continue...this job is easier with a snap on valve adjust ment tool that has the the screwdriver attached to the tool.
gsr96cx
Aug 30, 2008 01:24 PM
4DRmafia
23
Jan 23, 2005 06:10 PM
95gsr
Apr 8, 2003 07:20 AM
White Lightnin
Mar 10, 2003 09:30 AM
FitCRX
Jan 21, 2003 01:21 AM
