Valve Adjustment (did search)
Ok I have the special tool, and I understand the procedure except for one detail that I cant figure out from the various tutorials on other sites. Where do you place the feeler gauge. I put it directly under the cam next to the valve adjuster screw, b/c on cspeed that appeared what they were doing. In the helms it appers to be on the large lobe in the center, and on bseries it shows them doing it right under the screw. Which one?
Re: Valve Adjustment (White Lightnin)
You put it between the lobes on the cam and the rocker.
On all lobes. Not just the middle or the Primary and Secondary.
Re: Valve Adjustment (Spade)
Ok, I think I was doing it right then. I put it on the bottom side of the cam directly next to the valve adjuster.
Basically if you have the valve cover off each cylinder has sort of three divisons on the cam and I did it on the outer ones. Correct?
hondaapi
12-12-2006 05:17 AM
HondaFanatic708
15
06-03-2004 04:36 AM
