ways to increase compression on my d16y8
Old Jul 7, 2002 | 05:06 PM
illmatic_si's Avatar
New User
Default ways to increase compression on my d16y8
I got toasted last night by someone running a 'mini-me' setup. the dude said his y7 block + y8 head yields more torque in higher revs than my stock y8 because of the higher compression ratio.
from what I understand, one way to increase compression in an engine is to bore the cylinder heads and get oversized pistons. is this the only route? and if it is, what specifically is involved? does this also increase displacement?
any help/info/experiences would be appreciated.. lates!!!
Old Jul 7, 2002 | 05:51 PM
lazy bum shaughn's Avatar
Default Re: ways to increase compression on my d16y8 (illmatic_si)
I think you mean bore the cylinder sleeves, not head. Why dont you get a VTEC head(D16Y8 head), it shouldn't be too expensive at all.
Ways to increase compression is to get higher compression pistons, or a thinner head gasket.
Old Jul 7, 2002 | 05:56 PM
FSTASNTZ's Avatar
You can mill your current head. Reducing the effective size of the combustion chambers, thus upping compression...
Jason
Old Jul 7, 2002 | 11:11 PM
ImportHatch's Avatar
Default Re: ways to increase compression on my d16y8 (FSTASNTZ)
he has a d16y8 so he already has a vtec head....You could mill your head to get a higher CR.
Yager-
1990hondaHF
11
Apr 1, 2004 10:17 PM
d15maverick
Mar 25, 2004 06:23 PM
quicksol95
Nov 20, 2003 06:46 PM
chictunner97ex
Jun 30, 2003 09:15 AM
