Clifford RSX3.5 installation problem
Old Mar 8, 2008 | 01:01 PM
viet_boi_racin's Avatar
Default Clifford RSX3.5 installation problem
So, I'm installing this alarm in a 95 Integra. I hooked up the power wire, the ground, the siren, the lock and unlock and such. Just the basic stuff. None of the ignition cut or the remote start stuff yet. I'm just testing it to make sure the brain is good and it locks and unlocks and such.
But i'm not getting a response from the brain when I hit the the buttons on the remote. I know the brain is getting power because the shock sensor flashes when it gets touched.
Anybody have any ideas on whats going on??
Old Mar 8, 2008 | 01:53 PM
fcm's Avatar
fcm
Old Fart
Default Re: Clifford RSX3.5 installation problem (viet_boi_racin)
You may have to program the remote, to do so you will need the ign. input, you will need to install the remote start relay pack to get ign. input, or if you are not doing remote start, [and you should not be if your G3 is a 5 speed] use the yellow lead in the ribbon harness and connect it to a "true" ign. source, [black/yellow in ign. harness] you can remove, [de-pin] the rest of the leads in the ribbon harness.
For the system to work all you need is 12V+ constant power, [red H1/2] ground, [black H1/5] siren output, [brown H1/3] and the siren grounded, the LED, valet/program switch and ant. plugged in.
If the system does not respond to the remote, the remote will have to be programed to the alarm or you have a problem with the system, either a defective R/F section in the main unit or the ant. is defective or not plugged in properly.
To test any farther you need to connect up "ign." to the main unit. 94
Old Mar 8, 2008 | 02:50 PM
Default Re: Clifford RSX3.5 installation problem (fcm)
thanks for the response. I figured out the problem. The brain was dead out of the box. I took the brain out of my other car and plug it in. and everything works.
Old Mar 8, 2008 | 04:45 PM
fcm's Avatar
fcm
Old Fart
Did you use the remote from the other car also, or were you able to program the new remote to it? 94
Old Mar 8, 2008 | 07:29 PM
I tried to program the remote to the brain. But I didn't get any response at all. Tried it about 10 times, No response at all. So I decided to pull the brain out of my other car and try it. and everything works. So that confirms the wiring was done correctly.
Old Mar 8, 2008 | 09:14 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
were did you get the alarm brain ?
Old Mar 8, 2008 | 09:49 PM
Default Re: Clifford RSX3.5 installation problem (wrx-killer-Sti-eater)
My buddy bought it from a member on here. Never got around to installing it. And had me install it today. I'm waiting until Monday to give Clifford a call and what my options are.
I tried looking around to see if any places would sell the brain alone, or brain with remote. I know its a long shot, because those are the most important and most expensive part of an alarm. But couldn't find any places that sells them.
Old Mar 9, 2008 | 01:28 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by viet_boi_racin &raquo;</TD></TR><TR><TD CLASS="quote">I tried to program the remote to the brain. But I didn't get any response at all. Tried it about 10 times, No response at all. So I decided to pull the brain out of my other car and try it. and everything works. So that confirms the wiring was done correctly.</TD></TR></TABLE> I meant did you use the remote from the alarm brain in the other car to test the wiring in the "new" car, or did you try and program the new remote to the alarm from your other car, meaning maybe the remote is the problem and not the alarm brain. 94
Old Jul 26, 2009 | 03:15 PM
Tweety-TechPRDM's Avatar
New User
I got a ef and i have the Clifford RSX3.5 alarm and when i swap the engine, the battery was out and now after like 3 month later i got the battery back to the car and the alarm doesnt work. I put it in valet mode and turn of and still nothing is working, I need help to reprograming the whole system back.
Old Jul 27, 2009 | 05:49 AM
fcm's Avatar
fcm
Old Fart
If you can put it into and out of valet with the valet/program button then it is a good bet that the only thing wrong is the remote(s) need to be reprogrammed.
Page 34...
http://www.directeddealers.com/manua...9564_07-05.pdf tach programing is on page 32. 94
Jhofbauer94
Audio / Security / Video
Jan 29, 2014 05:02 AM
Drifterxs12
Sep 16, 2008 10:56 PM
dragonjay006
May 24, 2008 06:54 AM
egriego4
Apr 29, 2007 06:56 PM
asianspeed
12
Jan 10, 2003 06:02 PM
