Keyless Entry help
Old Apr 29, 2007 | 11:29 AM
egriego4's Avatar
Default Keyless Entry help
Ok so Yesterday I pulled my interior and began installing the "Stealth Alarm" created by suspendedHatch. Everything went perfect, and alarm and sensors work perfect. However the only problem which I am having is the keyless entry. My car has no keyholes for the driver and passenger. The only way to open the car was thru the trunk heyhole. My goal is to finish the install so I can only open my car with keyless.
Alarm Viper5000
Install: 7-pin harness: I followed the install and connected the blue/black wire to the OEM black/red "Power Unlock Wire." I connected the Green/Black wire from Viper harness to the OEM black/white "Power Lock Wire." I also connected the Violet/Black wire from the Viper Harness to a Constant 12v. Also the Black/White wire to a ground.
The manual states that the default settings, when I arm the car it shoudl lock it, when I disarm the alarm it should unlock it.
Checked: The power lock fuse is good. The connectors in the door panel are connected to the locks.
Any help and experiences are greatly appreciated. I cant figure it out
Old Apr 29, 2007 | 01:59 PM
fcm's Avatar
fcm
Old Fart
Default Re: Keyless Entry help (egriego4)
My question would be, what do you do when you come back the car and it has a dead batt.?
Do the power door locks work work normally, [with the door switch]?
The Viper 5000 has door lock relays built in, how did you wire the door locks? 94
Old Apr 29, 2007 | 02:56 PM
egriego4's Avatar
Well I also have the battery backup, so if the battery is dead I have that.
Yes when I lock the doors from the driver side it locks the rest.
"I followed the install and connected the blue/black wire to the OEM black/red "Power Unlock Wire." I connected the Green/Black wire from Viper harness to the OEM black/white "Power Lock Wire." I also connected the Violet/Black wire from the Viper Harness to a Constant 12v. Also the Black/White wire to a ground."
Thats how I wired them...
Modified by egriego4 at 4:35 PM 4/29/2007
Old Apr 29, 2007 | 03:10 PM
00preludesh's Avatar
you may have negative locks ...then need to grounf violet/black
Old Apr 29, 2007 | 06:09 PM
egriego4's Avatar
Can anyone confirm this? Do you 98 integras have neg. or pos. door locks? I dont want to try and ground them without knowing for sure.
I searched and it just tells me the wire color of the locks not if they're neg or pos.
Old Apr 29, 2007 | 06:56 PM
egriego4's Avatar
I got them to work! Thanks to 00preludesh's advice. They locks were neg so the violet/black wire needed to be grounded!
Thanks!
lurice01
Audio / Security / Video
Jun 10, 2015 09:14 AM
BrotherAli
17
Oct 19, 2012 11:56 AM
chocolatesk8er10
19
Oct 2, 2011 10:09 AM
scottmog
Oct 22, 2008 11:14 AM
stingray072
Aug 16, 2004 04:45 PM
